May 10th, 2006, 2:30 pm
No high beam??
I have a 2000 996. I just took off my track skins and put on my street stuff and my high beam light does not work. I am pretty sure it is my high beam . Sitting on the bike, the light on the left is on. I checked the fuses, bulbs, and switched the light relays. The right light will not come on at all when I turn on the high beams. Any help/guidance will be greatly appreciated..Thanks, Jay
May 10th, 2006, 5:05 pm
Sounds like the Bulb's failed.
916 & M944 'project'.
May 11th, 2006, 7:12 am
Evil moderator
Yepp. probably a bulb.
Specs are: H1 55w stock bulb.
You need to remove your front fairing and your headlight to change it. Remember to point the bike at a wall from a known distance to see what height to re-adjust the headlight to after you´ve taken the headlight of the headlight holder and replaced the bulb.
//amullo
Check that your getting voltage to the wiring
//Anders
-10 Multistrada 1200S Sport - Fast by Hypertrick
May 11th, 2006, 10:34 am
Thanks a bunch for the replies, but I have a new headlight and it still does not work. I am going to replace both relays then start with the wiring. Thanks again
May 11th, 2006, 4:07 pm
I'd check the connectors @ the bulb. I've had two connectors fry/melt on me causing an intermitent shorting...
May 12th, 2006, 6:46 pm
The connectors are good.... I replaced the relays and the light worked...then I mounted the lights, tried the high beam again, and it was not working..WTF. I tested the relays with a 12 volt battery and a ohm reader. the relays were clickin and registered 0 resistance, which usually means they are good..once again WTF? Can I have a short somewhere? The wires look good, fuses are good. Damn finicky Italian motorcycles. Thanks for the help..Jay
May 12th, 2006, 10:26 pm
Well I just went out into the garage to throw some stuff in the dryer. I tried the lights on the bike, and the high beam works!!! I have no idea what is going on. My next call is going to be to a priest, so he can exorcise my Duc!!
May 12th, 2006, 10:27 pm
What about the switch? bypass it @ the fuse and complete the circuit to ensure your circuit is good without the switch in play...
May 13th, 2006, 10:22 am
I figured the switch would be good, cause my horn and signals work. The light is still working now, so I think it could have been the relay. It is still weird how the light would work when it wanted to. Thanks for the replies..
