999 Crank No Start No Codes - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Sep 10th, 2008, 8:17 pm   #1 (permalink)
Structure3230's Avatar
Thumbs down 999 Crank No Start No Codes
Hello Everyone,
I need some ideas as I am experiencing a crank no start condition. Ok here is the story:
Just installed a 54mm Termi full exhaust - started it up many times over the last 3-4 days without any problems. During tightening the header bolts I removed the battery tray to gain a better access to the bolts and afterwards the bike started cranking longer than usual but STILL started. Checked all the connections and everything looks good. Left the bike overnight and worked on getting my seat and fairings back on however now the bike does not start (it just cranks). Checked battery voltage and its about 11.8 now (after starting it a bunch of times). Hooked the bike up to my car to jump start it - battery voltage up till 13.8 and still cranks no start. I def. smell fuel and hear the fuel pump priming however I dont want to keep cranking in fear of flooding the cyclinders (I'm already expecting a big fireball the first time this thing starts again).
Any ideas? It doesnt seem to have any fault codes, I suspect the fuel is okay (didnt check pressure though), and I haven't checked spark yet. The tank was low in gas so I filled it up with fuel as well but still same issue. However after disconnecting the battery is there adaptations or some type of timing that can get messed up? The bike was just running like a champ. Some people might ask me to recheck the connections at the ECU but other than that what do you guys think? Which connections in particular at the ECU should I look for (pins, crimps, splices, wires, fuses, or connectors)?
Fuel delivery (havent checked the pressure), jumped the battery, havent check the spark (what the recommended way of checking it on the 999)? What else? Why would the bike suddenly be harder to start after a battery disconnect and now not start at all? What the heck....
Thanks in advance guys...I hope someone can shed some light.
2005 Ducati 999
2009 BMW 335d
2008 BMW 335i (sold)
2007 BMW 335i coupe (sold)
2006 BMW Z4 (sold)
2005 BMW Z4 (sold)
2005 BMW X3 (sold)
2005 GSX-R 600 (sold)
2004 EVO VIII (sold)
Structure3230 is offline   Reply With Quote
HELP 999 wont start 999RDale Superbikes 8 Jul 16th, 2008 2:36 am
999 cold engine start parmic Superbikes 4 Jul 2nd, 2008 10:58 am
03' 999 EOBD light is on... won't start subydude Superbikes 4 Jun 28th, 2008 12:37 am
999 no start: flashing rev limiter? clenart50 Superbikes 0 Jun 9th, 2008 11:01 am
998 Loves to Crank, but Doesn't Start turn1 Superbikes 16 Sep 9th, 2006 9:49 am
