uh oh.... Wrench light came on on dash? i JUST had 6k service.. - Ducati.ms - The Ultimate Ducati Forum
Old Aug 29th, 2008, 6:38 am   #1 (permalink)
(Ducati 749)
Well it started flashing at I dunno, 6150, 6200 miles? And after some more miles went solid.. I almost stopped and tried to assess this but I figured it would be fine?
I'm assuming that X amount of miles after 6k it flashes to remind you of service due?
Well now its solid and won't go off. If I am correct, how can I reset the 6k timer?
I'm assuming that's what it is...
eingeist is offline   Reply With Quote
Old Aug 29th, 2008, 8:57 am   #2 (permalink)
Havin a Time
Chuckracer's Avatar
Images: 2
Only the dealer can re-set that light.
S.O.D.O.M.
Old Aug 29th, 2008, 9:32 am   #3 (permalink)
dizzy999s's Avatar
Yeah take it back and have them reset it.
Sean.
'06 999S Mono
dizzy999s is offline   Reply With Quote
Old Aug 29th, 2008, 10:31 am   #4 (permalink)
I would other than the fact the dealer is 90 miles away
Old Aug 29th, 2008, 11:13 am   #5 (permalink)
Duc for life
GuiTsouo's Avatar
Dealer should have told you that you hadn't reached the appropriate mileage for the wrench light to come and that you'd have to come back. The trigger is based on Km, so the actual mileage number is a little whacky:
600 mile service light comes on at about 621 (1000 Km)
6000 mile service light comes on at about 6213 (10000Km)
7500 mile service light comes on at about 7456 (12000Km)
Doh!
Cheers,
gui
'08 848
'98 46th RC46
Past:
Suzuki GSF600S
Honda XR600R
GuiTsouo is offline   Reply With Quote
Old Aug 29th, 2008, 4:18 pm   #6 (permalink)
Havin a Time
Chuckracer's Avatar
Images: 2
Then live with it.
S.O.D.O.M.
Old Aug 29th, 2008, 4:36 pm   #7 (permalink)
Chilehead
st2lemans's Avatar
Images: 95
Turn on the key with the LH dash button depressed. Works like that on my SS, not sure about my 999R as I used my VDSTS to reset that.
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
Old Aug 29th, 2008, 4:47 pm   #8 (permalink)
galaxy's Avatar
Images: 27
Holding the button while cranking doesn't work on the XX0 bikes. That little wrench being on doesn't do a darn thing. Mine's been on for about 15,000 miles now :-)
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Aug 29th, 2008, 4:56 pm   #9 (permalink)
Good enough for me!
Old Dec 1st, 2009, 9:12 am   #10 (permalink)
Turboflyer's Avatar
If that works, button and key. Let me know please. I know from reading the manual you can get into some programing modes on the 999 panel if you are not careful. So there must be some walk around to that and other setting Ducati does not want to reveal. Any good hacks out there? Of course they tell you to turn the key off and take the bike to the dealer.
Turboflyer is offline   Reply With Quote
service engine light at 150mph? MrDude_1 Superbikes 3 Mar 17th, 2008 3:13 pm
Turning off the little wrench light levine98 Sport Touring 2 May 12th, 2007 10:16 am
Refused Service on my Ducati at a Ducati Dealership hawc Ducati Motorcycle Chat 73 Feb 10th, 2007 7:31 pm
Dash Board Turn Signal Indicator Light ST4s 2UpDuc Sport Touring 1 Apr 28th, 2006 1:48 pm
