999 High comp. pistons/porting - Ducati.ms - The Ultimate Ducati Forum
post #1 of 10 (permalink) Old Feb 2nd, 2008, 5:34 pm Thread Starter
ZDM
Super Senior Poster
Opinions please..... went down to Fast by Ferracci today and talked to them about doing a high compression piston and port performance upgrade to my 03' 999. I was going to do a "stroker" kit but it's too expensive. Right now I have a 54mm full exhaust, DP ECU and PCIII custom mapped. I had the mapping done when I had a Termi 1/2 system. The PCIII along w/the ECU and 1/2 system gave me 130/77. Now I have a new DP ECU along with the 54mm full system and haven't had it remapped because it's running too well right now. So... has anybody installed high comp. pistons in their 999 running a similiar set up. I not a horsepower junkie but I'm wondering if this is a worth while upgrade. Its about $1500 all together for the work.
ZDM is offline
post #2 of 10 (permalink) Old Feb 2nd, 2008, 8:30 pm
We've got a 06 999s in the shop right now getting a set of hi comp pistons installed, should be done towards the end of next week. Once it's all done i'll let you know how it is.
tyler748 is offline
post #3 of 10 (permalink) Old Feb 2nd, 2008, 8:37 pm Thread Starter
ZDM
Super Senior Poster
Cool!!! Thanks Tyler!
ZDM is offline
post #4 of 10 (permalink) Old Feb 2nd, 2008, 11:25 pm
osayek's Avatar
yeah i'd be interested to find out as i've been wanting to do this for the longest time.
you should also consider lighter rods and lightened crank...and cam work....
tyler, what shop did you take yours to?
05 Ducati 999s Full Track/Race
06 Ducati 999 mono
01 Kawa 9R
97 honda shadow
94 kawa 250
91 vespa piaggo 250 still runs
osayek is offline
post #5 of 10 (permalink) Old Feb 3rd, 2008, 11:05 am
999 big bore kit
bcm has 102mm big bore kits 2006 999s with 57mm termi 136 rwhp. same bike with BCM 102 kit with stock heads and stock cam timing 148 rwhp They have been racing a bike with this set up for 2 seasons with 0 problems. kit is pistons and nickasil cil ,job done in the frame 10 hour job
mr-x is offline
post #6 of 10 (permalink) Old Feb 3rd, 2008, 12:30 pm
I hear airplanes
TAftonomos's Avatar
I'm gonna have to call them on monday because of you. 150 rwhp with a fully tuned nemisis can't be to hard if they got 148 on stock heads! Maybe in the mid 150's with ported heads.
Boring is the way to go, stroking it is only going to be harder on the motor, and require larger ports to get the most out of it. Piston speed will be higher, etc...
The roads are flat I bought a harley!
TAftonomos is offline
post #7 of 10 (permalink) Old Feb 4th, 2008, 2:01 pm
999 big bore kit
call them on tuesday and talk to leslie the owner or miles at the front counter they are very helpfull. they are currently installing a 100mm fx kit in my 749r i was impressed when kyle showed me the power curves from the 102mm 999s and when i was there kyle was porting the 102 and freshining the motor after 2 race seasons. the pistons that came out were mint with no visible signs of wear after all the race time he felt that in the street applications they will have absolute no relibality issues.They told me all there parts are race tested before they go on a single street machine
mr-x is offline
post #8 of 10 (permalink) Old Feb 14th, 2008, 3:41 pm
Tyler, any update on the 999S with high comp?
devilisht2003 is offline
post #9 of 10 (permalink) Old Feb 14th, 2008, 3:51 pm
Bikes all together, owner also installed a yoyodyne lightweight flywheel. Just waiting for a decent day to take it for the test ride, we just got a bunch of snow and ice so that's gonna mess things up for alittle while.
tyler748 is offline
post #10 of 10 (permalink) Old Feb 19th, 2008, 6:04 pm
703motogp's Avatar
Ducpond
Hey all! I just dropped off my 03 999 at DUCPOND motorsports in Winchester, VA. I met Donnie and his wife and took me on a lil tour of the shop as well! All I have to say is that he is a very very cool person and that I can't wait till I finish the rest of my tour in the middle-east so I can ride my 999!
I was gonna take it to the local dealer to get the 6,000 miles service, but one of the mechanics told me about the DUC POND and I was going to get my cylinder heads ported and all and get the Pistal high compression pistons insalled. So I am getting my 6,000 miles serive and all that above at DUC POND while I am gone. Im also gonna get a valve angle job and etc.... So I can't wait to get back and feel the outcome!
It will be dyno tuned over there as well and as soon it is finished I will get the numbers and let you all know!
http://ducpond.com
*ACE*
LIVE LIFE TO THE FULLEST!!! YOU ONLY LIVE ONCE!
703motogp is offline
Human Verification
Stay away from high output (90/100w) bulbs!!! DrD Sport Classic 20 May 8th, 2013 9:25 am
High Comp Pistons Keyboard Superbikes 2 Mar 7th, 2007 3:43 am
living at high altitude roadron Supersport 1 Nov 27th, 2006 5:58 pm
No high beam?? jaymags Superbikes 8 May 13th, 2006 10:22 am
