I'm planning to install a Zard full system on my MY2003 999R tomorrow. Looks to be easy and straight forward, but is there anything special I should know about?
Thanks,
Tom
Thanks,
Tom
How do you like your Xerox with the full system?My Xerox has the full system and it is wrapped plus I have the heat shield taped to the inside of the fairing. No problems.
Good Luck.
Larry
Street use with perhaps one TL/day, maybe one STOP sign/hr, and no sitting in traffic (filtering/lane sharing is legal).As well, how will you use it? If you'll start the bike and hit the track going fast, there will probably be enough ventilation going through that you won't get any hot spots unless the pipes come within, say, a half inch of the fairing. If it will see street use where you'll have to stop and idle at stoplights and traffic, then you have to take extra heat precautions because heat will build up and fry anything close to the pipes.
I had no such problem, evrzthing fit just nicely!have the old round style 57 m/m Termi on my 999 series and there is just no way to fit the rear bottom fastener.
