Ok 853 still going, Custom R Airbox time... - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Dec 16th, 2007, 10:15 pm   #1 (permalink)
Bobaganoosh
Synergy's Avatar
An old saying goes if your going to be slow, build a fence around it, cause your milking it! Well there is a nice picket fence around my 853. Since this has to have been the longest 853 build in Ducati History! I have been tied up with women, other toys, a 749 and working on other Ducs on the side. My project has been neglected.
My brain is always working, in a mad scientist kinda way and often sometimes backwards. For the new guys I blew a 748 up, built a 853(fully built B&B) and decided to powder coat the frame, Penske suspension, blah blah blah, the credit card bills go on and on. So after I got the motor into the freshly coated frame. I found a screaming deal on R shower injectors. Well R frames have a different cross member than all other frames. So I could drop the motor cut the frame, re-weld, then re-powder coat. Or lets cut the airbox up and build it "more gooder" (to quote Opie & Anthony)
So here is my current project, taking my knowledge plus what I seen on the internet and Mythbusters to build a custom, possibly CF lower airbox. For the Showers on a non R frame.
I will be keeping all the pics on a Photobucket album, since it will be quite detailed.
http://s2.photobucket.com/albums/y39...%20Airbox/
My plan:
-Use a smaller fan (I still drive in LA traffic) to enable a larger airbox in the frame.
-Move the radiator as far forward to still clear the front tire while enabling larger airbox volume.
-Build a thin aluminum or balsa frame to fill in where I have made cuts.
-Then line the inside of the airbox with foil, spray with Pam and then use high expansion foam to make a negative impression of the airbox.
-From the negative I can make a Fiberglass or CF airbox....Hopefully.
I am looking for thoughts, suggestions, anything you guys have to offer, especially with CF or Glass work.
Just the Showers, the injectors have been removed to be cleaned and flow matched.
In a Michigan State University study that ranked 34 major countries by their citizens' acceptance of the theory of evolution, the United States ranked second to last (thank you, Turkey). 39% of our adult population rejects the concept.
Synergy is offline   Reply With Quote
Old Dec 16th, 2007, 11:14 pm   #2 (permalink)
Bobaganoosh
Synergy's Avatar
Trial of foam filling is up on my album. All pics have detailed descriptions.
Old Dec 17th, 2007, 1:18 am   #3 (permalink)
Banned
Images: 15
So again, you want shower injectors because? I've got a 748R with no shower injectors PURPOSELY so I didn't have to deal with'em. Runner intake length and diameter is far more important then injector positioning or type. Plus your talking about using the ORIGINAL shower injector system and computer, which both not so hot with idling. Hmm... IDK, sounds to me like your goin' out on a tree branch with nothing to protect your fall. It'll work, sure... but is it worth it?
I'm gonna dyno my bike soon and post the numbers, I can almost guarantee they are right around stock w/o the showers.
tye1138 is offline   Reply With Quote
Old Dec 17th, 2007, 3:16 am   #4 (permalink)
Bobaganoosh
Synergy's Avatar
Obviously you don't understand what Showers can do for a bike. Have you spent countless hours talking with Marc Salvisberg? Do you know who Marc is? Are you going to run his chip and then take your bike directly to San Rafael so he can tune it personally? If not your talking about stuff over your head.
I built my motor with an intial limited budget and plans for future upgrades. The foundation is a bullet proof bottom end. My investment was spent in the Stage II crank, bearings, con rods with balance and blueprinting, all wear parts ceramic coated for anti-friction or heat dispersant. You of all people should know a bulletproof bottom end is worth more than the best heads you can buy. Heads are easy to pull and send off for big valves and hot cams to fully take advantage of the Shower injector system.
Tye thanks for your informative post! BTW where are those pics of your blown up crank and big ends?
Old Dec 17th, 2007, 5:32 am   #5 (permalink)
jspringm's Avatar
Good luck on your project. All I have to add is "take your time". I looked around and found this sight a lot of help. Especially building the molds and laying up the carbon fiber. http://www.fibreglast.com/contentpag...enter-286.html
2004 749s (the faster color)
jspringm is offline   Reply With Quote
Old Dec 17th, 2007, 2:25 pm   #6 (permalink)
94CobraR's Avatar
Images: 5
Never had idle issues or low-RPM issues with my 748R and injectors...had a chipped burned and I used it as a *gasp* STREET BIKE!
Love the build-up, keep it going!
Jimmy
Go Gators
www.g8rduc.com
94CobraR is offline   Reply With Quote
Old Dec 18th, 2007, 2:15 am   #7 (permalink)
thatkidchris's Avatar
Look thru this guy's threads. Tons of real world how to. I actually believe he may be a member here also. His work encouraged me to build a carbon clutch cover, repair some race fairings, and I guess Ill have to make a new hanger for my exhaust with the info soon.
http://www.bayarearidersforum.com/fo...5&pagenumber=1
thatkidchris is offline   Reply With Quote
Old Dec 18th, 2007, 6:26 am   #8 (permalink)
Darkside's Avatar
Thumbs up for the innovation. Will watch with interest. Have played with carbon but am too amateur to offer advice.
Have the showers std on my 998s, No idling driveabiliy issues on street and love passing my mate on the back wheel when he is on his non s 998 on the track
Darkside is offline   Reply With Quote
Old Dec 18th, 2007, 9:57 am   #9 (permalink)
srg5150's Avatar
Where can I source a set of the aluminum injector mounts?
'02/'05 Ducati 998/999R combination
Lots-o-CF & Billet lovin with BST's
More custom parts than I can count
2008 Ducati Concorso Troy Bayless award
"Best Superbike"
Now racing WERA... an addiction worse than crack
The money pit continues...
srg5150 is offline   Reply With Quote
Old Dec 18th, 2007, 10:42 am   #10 (permalink)
Bobaganoosh
Synergy's Avatar
That is the shower type injector system off 748R bikes. Its not just a injector mount, its a complete 2 piece airbox, intake manifolds and injector assembly.
Guys thanks for the links and suggestions. I have researched the fiberglast page before. Well I came home from work this morning and found my trial and error of injecting high expansion foam in the airbox, did quite work the way I planned. I will get some pics up later. I may also try making a template mold from floral foam and hand shaping it to fit the frame.
Airbox Volume Effects Shazaam Hall of Wisdom 7 Jul 9th, 2009 6:21 am
General airbox question TrojanHorse Ducati Motorcycle Chat 8 Dec 12th, 2007 5:08 pm
Stupid Question Time: What's Everyone Using For Chain Lube? kmh364 HyperMotard 28 Oct 1st, 2007 6:06 pm
Question about a PCIII custom map for my '04 999 kabinski Superbikes 3 Jun 19th, 2007 5:39 pm
