will older 916-998 front wheels fit a 999 - Ducati.ms - The Ultimate Ducati Forum
post #1 of 8 (permalink) Old Dec 16th, 2007, 4:23 pm Thread Starter
ahastings's Avatar
I know the rotor bolt pattern is different, but what about the spacing. The reason I ask is I am getting an 848 and turning it into a racebike immediately so I will need to get some spare wheels. The rears I already have found out are the same as the old 916-998 except in 5.5" which makes it easy to get 6" wide wheels. The fronts are the same as the 999 series I believe with 320mm rotors. So If I could make the 916 fronts work then I can get a set made for that bike as long as use those rotors.
Arnie
ex Ducati racer
2006 CCS MidAtlantic overall Expert #3
2007/2009 CCS MidAtlantic overall Expert #1
2010 CCS Atlantic region Overall Expert #1
2007 WERA Expert Heavyweight Twins Superbike National Champion
ahastings is offline
post #2 of 8 (permalink) Old Dec 16th, 2007, 9:13 pm
Ducati.MS sponsor
moto's Avatar
Images: 30
748-998 use a 10mm offset rotor, different axle spacing and different fork bottom offset than the 749-999 series. It is also set up for a speedo drive - so a spacer may be required.
The 848-1098 use basically the same wheel as the 999 (15mm rotor offset/5 bolt) but use a different axle. There are a lot of these around for cheap and would might be an easier swap.
Email Matt@motowheels.com or give him a call at 916.369.2509. He is more familiar with the little details and differences.
We get trade in on the base 1098 wheels for BST wheels from time to time. If you let Matt know he can contact you when any come up.
-M
www.motowheels.com
05 999R
01 996R
98 900SS FE
96 M944 (sold)
07 1098
06 SC1000
10 Streetfighter
10 M696
02 MV Agusta F4
02 ST4S
12 1199S
06 Paul Smart
15 Scrambler FT
moto is offline
post #3 of 8 (permalink) Old Dec 16th, 2007, 10:14 pm
rodericb's Avatar
M, is there any interchangeability for rear wheels between the 748/916 and the 1098 or the 848?
Rod
999R 03 #0069
Italjet Dragster 180
Kaw ZX9R C2 fixxerupperer for fun aka The Ginger Ninja
rodericb is offline
post #4 of 8 (permalink) Old Dec 16th, 2007, 10:49 pm Thread Starter
ahastings's Avatar
I have been told that the rear 848 is the same as the Hyper,916-998,Late S4 and S2. But the 1098 is all by itself, it has a bigger axle.
Arnie
ex Ducati racer
post #5 of 8 (permalink) Old Dec 17th, 2007, 3:07 pm
You out of the LW class next year Arnie (hoping ... hoping ... hoping)??
xseal is offline
post #6 of 8 (permalink) Old Dec 17th, 2007, 3:23 pm Thread Starter
ahastings's Avatar
For now, unless Ducati offers some good contingency in LW, I might have to pick up a Hyper and turn it into a lightweight weapon. . My 848 is getting stripped down this week.
Arnie
ex Ducati racer
post #7 of 8 (permalink) Old Dec 17th, 2007, 11:24 pm
Lets hope they don't ... 'cause if not, 08 is shaping up to be a promising year.
Can't wait to see the 848 in action. Save me second place in the SupTwins.
xseal is offline
post #8 of 8 (permalink) Old Feb 24th, 2008, 11:39 am
toobs1234's Avatar
Anyone know if a 1098 hub assembly will fit into a 998 swingarm so that 1098 wheels can be used?
Paul Smart 1000
toobs1234 is offline
Human Verification
Front Brake Drag on a 999 Soarer Superbikes 7 Jul 18th, 2007 12:35 pm
it's Friday, let's talk Lightweight Wheels :) DogTown749S Superbikes 33 Jun 27th, 2007 10:56 am
wheels wheels wheels redbike Supersport 3 Feb 22nd, 2007 7:13 pm
Trying to remove my wheels... front is stuck actionong Superbikes 19 Feb 21st, 2007 2:05 am
I got my Front Axle out... AND MY BIKE SLIP OUT OF THE STAND! actionong Superbikes 11 Feb 20th, 2007 5:13 pm
