Sprocket change...Nut size??? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
Old Oct 30th, 2007, 6:29 pm   #1 (permalink)
Mr_Chow's Avatar
So i come to find that my chain had some wicked loose spots in it and decided to change out both sprockets as well. The rear sprocket requires that you loosen and remove both the wheel and carrier from both the left and right side. I know these nuts are rather large, but even my haynes manual contains no information pertaining to the size.
I'm guessing 46mm on the wheel side and 36mm on the sprocket side? Can anyone give me some exact measurements?
Thanks guys
Mr_Chow is offline   Reply With Quote
Old Oct 30th, 2007, 6:43 pm   #2 (permalink)
tomy2k748's Avatar
46mm and 41mm
2005 KTM 450SX
1997 KTM 360SX
tomy2k748 is offline   Reply With Quote
Old Oct 30th, 2007, 8:10 pm   #3 (permalink)
Mr_Chow's Avatar
thank you! can anyone else confirm this?
Old Oct 30th, 2007, 10:18 pm   #4 (permalink)
1fast750ss's Avatar
Originally Posted by tomy2k748
46mm and 41mm
+1000
Brian C.
'01 BCM 795SS / Track Toy
'03 999 w/50mm termi, S cams, BST wheels / daily commuter?
www.podiumracing.com
Maker of fine Ducati performance Parts and Accessories
1fast750ss is offline   Reply With Quote
Old Oct 30th, 2007, 10:27 pm   #5 (permalink)
Havin a Time
Chuckracer's Avatar
Images: 2
Where's the trust?
S.O.D.O.M.
Old Oct 30th, 2007, 11:31 pm   #6 (permalink)
danielspdx's Avatar
If you're talking about the classic superbike with the SSA, you don't need to remove the wheel, just the sprocket carrier (41mm) side.
danielspdx is offline   Reply With Quote
Old Oct 31st, 2007, 8:45 pm   #7 (permalink)
Mr_Chow's Avatar
yea sorry guys...its a 2001 748
Old Oct 31st, 2007, 9:02 pm   #8 (permalink)
AM-A-Duc's Avatar
Originally Posted by Chuckracer
Where's the trust?
yea !
07 999 Parts unlimited, Pazzo shorties, 38t sprocket, 57mm ceramic coated termi, Dp ecu, PCIII
AM-A-Duc is offline   Reply With Quote
Old Nov 1st, 2007, 7:13 pm   #9 (permalink)
Mr_Chow's Avatar
lol
No one in oshkosh WI carrys metric sprockets that large. I know you can use a SAE 1 13/16 for the wheel side, but i'm not sure for the other side 1 3/5???
Old Nov 2nd, 2007, 4:15 pm   #10 (permalink)
tomy2k748's Avatar
If you have a Harbor Freight close by you can get one there. If not I would order one from somewhere because there is really no standard size that is really close.
2005 KTM 450SX
1997 KTM 360SX
Sprocket change results Spinthehook Superbikes 1 Sep 1st, 2007 1:48 pm
999 rear sprocket change, can someone help me out? archer Superbikes 5 Jul 13th, 2007 5:17 pm
02 998S Stock Front Sprocket Size? Bike coughs at slow speeds/lower RPM's indetrucks Superbikes 5 Apr 4th, 2007 9:38 pm
Lowering The Gearing.....Change Front or Rear Sprocket? critterdoc Supersport 10 Aug 27th, 2006 4:30 pm
