New Airfilters, Performance Increase? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 17th, 2007, 11:32 am   #1 (permalink)
rapter's Avatar
Will putting new airfilters on my bike contribute to any kind of noticible performance difference?
I took these out a little while back and noticed that they were no longer the golden factor colour, but a tuff black colour instead...
My Scuderia : 2006 Ducati 749d - Showa TiN forks, Bitubo Steering Dampener, Ohlins rear shock (ARNOLD HASTINGS!!! AMA 2008 ), Dunlop 209/208 tires
rapter is offline   Reply With Quote
Old Oct 17th, 2007, 11:39 am   #2 (permalink)
the xx9 motors have cleanable filters. Just use a K&N Cleaning kit and you're golden. I personally don't notice a difference with cleaned filters but i think it would depend on how dirty it is in the first place.
Danny
2005 Ducati 999
2004 Yamaha R1
2003 Yamaha R6 (Track)
m3elmo is offline   Reply With Quote
Old Oct 17th, 2007, 3:13 pm   #3 (permalink)
gzinga's Avatar
I would think it will make a big difference when you are revving the engine at high speed cos of the air not getting sucked in as RAM effect....but then again...you would have to be on the track ....
what ever happens ... happens as it should.....
AFM #420
il motorino-Vespa Santa Cruz
MadDesigns
bikes: 999r Xerox, 1100HM, R6
gzinga is offline   Reply With Quote
Old Oct 17th, 2007, 3:29 pm   #4 (permalink)
Really? You are referring to the stock air filter? Interesting. Do you also use the K&N oil as a final treatment?
Lar.
ST3S is offline   Reply With Quote
Old Oct 17th, 2007, 3:38 pm   #5 (permalink)
S4one's Avatar
clean your filters..
06 749 Dark
Ohlins damper
Motowheels vented clutch cover
Motowheels gas cap
Full floating rotors
Pitbull spools
Cycle Cat GP shifter
Ducati Performace 41t rear sporket
Monoposta conversion
Remus slip on
Speedymoto SS springs and caps
Silverstar bulb
S4one is offline   Reply With Quote
Old Oct 17th, 2007, 4:43 pm   #6 (permalink)
rapter's Avatar
I did not know that one is able to clean the stock filter... is K&N air filter cleaner the thing to be using? is there not some kind of special oil that has to go on these airfilters before they are fitted back into the airbox?
Obvious one has to has to allow these filters to dry before re-installing them back into the motor.
it is about time Ducati made something that I can re-use on my bike!
Wooooot!
Thanks
Old Oct 17th, 2007, 5:33 pm   #7 (permalink)
AM-A-Duc's Avatar
Lar.
yep
07 999 Parts unlimited, Pazzo shorties, 38t sprocket, 57mm ceramic coated termi, Dp ecu, PCIII
AM-A-Duc is offline   Reply With Quote
Old Oct 17th, 2007, 6:47 pm   #8 (permalink)
you re-oil it to the same directions that K&N uses. The filter stock is white b/c the oil is clear/yellowish. IT will be pink/red when you're done with it now
I just recently cleaned mine. Now i can tell people i put a k&N filter on my duc...haha
Danny
2005 Ducati 999
2004 Yamaha R1
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 6 Dec 18th, 2012 6:04 am
999s increase performance?? BullyLvr999 Superbikes 21 Aug 11th, 2007 7:38 am
HM Specs and Info SouthsideDuc HyperMotard 8 May 4th, 2007 10:58 am
Performance ECU and Zard Exhaust 06Sport1000 Sport Classic 23 Mar 9th, 2007 8:48 pm
NEW!!! 1098 Specs Info and New Pics!!!!!!! Harry Superbikes 54 Nov 10th, 2006 11:15 am
