Chain Tight Spot Tips? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 25th, 2007, 1:27 pm   #1 (permalink)
james0133's Avatar
Images: 2
Smile Chain Tight Spot Tips?
Does any one have any good tips for getting tight spots out of a chain? I am hopefully getting a new chain and ridiculously expensive sprockets (the back that is) soon. But if any one has found any good tips I’d love to hear them.
2006 Ducati 999S (So Much Fun)
1994 Ducati 916 Strada (Regrettably Sold)
james0133 is offline   Reply With Quote
Old Aug 25th, 2007, 1:57 pm   #2 (permalink)
Shazaam's Avatar
Tight spots are where the chain has stretched the least or where o-rings have failed and lubrication is lost.
Chain Inspection and Freeplay Adjustment
Shazaam is offline   Reply With Quote
Old Aug 25th, 2007, 2:18 pm   #3 (permalink)
james0133's Avatar
Images: 2
Yes that is true. I have found when taking old chains apart that it is when the lubricant that is manufactured into the chain dries up and the internal pin starts to rust and bind.
It is very hard to get lube back in to an o-ring chain. Even WD40 does not seem to penetrate much. I was considering heating the chain or heating oil and soaking the chain in it.
Old Aug 25th, 2007, 3:39 pm   #4 (permalink)
It's too little too late, but soaking it in lube is probably the best method.
tjfdesmo is offline   Reply With Quote
Old Aug 25th, 2007, 3:56 pm   #5 (permalink)
Keep the chain clean and lubed. Proper slack helps too. I've found that alot of my buddies run their chain too tight, which wears the chain prematurely. I run about 1.25"-1.5" of slack with bike unloaded at the tightest spot on the sprocket (indeed, sprockets are not always perfectly round).
-MATT
'05 749R #233
Old Aug 25th, 2007, 4:02 pm   #6 (permalink)
twowheelcossack's Avatar
Toss it. That is the textbook sign of failure, save for outright snapping which'll be the chain's next trick. Remember, chains are cheap, a thrown chain is not.
2001 996SPS #1548
2001 748RS
2007 BMW R1200GS Adventure
"To do is to be"- Jean Paul Sartre
"To be is to do"- Aristotle
"Doobie-doobie-doo"- Frank Sinatra
twowheelcossack is offline   Reply With Quote
Old Aug 25th, 2007, 7:37 pm   #7 (permalink)
Nove-R's Avatar
I think that's it right there. I've never had a bike with a stock or aftermarket sprocket that was perfectly round, or that turned in a perfect circle. Might be a function of wheel or axle as well.
Put the bike on a stand, slowly turn the wheel and you'll see that it has more or less slack depending on where it is in it's rotation. May be very slight or pronounced. This is new, old, worn, not worn, Japanese, European, dirt, street, whatever.
Not saying that there aren't perfectly round ones, but I haven't seen one myself.
Streetfighers are built, not bought.
'05 999R
'00 955i/ GSXR1000 Streetfigher
'06 ZX-636 race bike
'08 KLR-685
'99 KZ-1000 Police Special
'84 VF500F Interceptor
999 or 998 Streetfighter (next build)
Nove-R is offline   Reply With Quote
Old Aug 25th, 2007, 7:42 pm   #8 (permalink)
Banned
Images: 15
I 100% agree! If your chain has links that are stuck, its dangerous and its a cheap fix! You can throw it in diesel and let it soak in, maybe bring it back to life, but it might cease up again!
On your bike, the chain install takes; what nove? 10 minutes? Well, it did not take very long at all! I bought a crazy expensive x-ring chain, but you don't have to do that, just get a standard DID chain and this time you'll take care of it better!
tye1138 is offline   Reply With Quote
Old Aug 25th, 2007, 9:09 pm   #9 (permalink)
Humble
Chuckracer's Avatar
Images: 2
Change your front sprocket too, James. It's as toast as your chain is, and a new chain and rear with an old front will eat the new parts quickly.
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
Timing belts- Tight spot! jas312 Superbikes 17 May 14th, 2007 9:41 pm
Installed new gears and chain. Have question. bpad1 Superbikes 3 Dec 27th, 2006 12:25 pm
