Exhaust note 999 vs 749 - Ducati.ms - The Ultimate Ducati Forum
Old Feb 17th, 2006, 7:47 pm   #1 (permalink)
gpd123's Avatar
I've heard the exhaust of a 999 with both a stock exhaust and a half Termi system. It sounded beautiful! Is there a noticeable difference in sound between the 999 and 749 with a Termi exhaust?
gpd123 is offline   Reply With Quote
Old Feb 17th, 2006, 8:33 pm   #2 (permalink)
galaxy's Avatar
Images: 27
I can't tell a difference between any I've heard with the same muffler.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Feb 19th, 2006, 9:39 am   #3 (permalink)
froggert's Avatar
not sure, but there was a change in the exhaust note of my bike when i big bored the 749 to 923cc. not sure if it's the higher compression or bigger bores though.
froggert is offline   Reply With Quote
Old Feb 19th, 2006, 6:46 pm   #4 (permalink)
racedfila749's Avatar
here did you get this big bore kit and how much
Yellow 04 749.
Motowheels clutch kit
Termi half system
D.I.D gold chain
Sprocket Spec. +5 rear
Cyclecat Gold GP shift lever
Puig DB windscreen
racedfila749 is offline   Reply With Quote
Old Feb 19th, 2006, 8:40 pm   #5 (permalink)
tarochan's Avatar
I have a mate with a 748R and that, in my opinion is the best sounding Otto valvola that I've heard.
Ok, how did you get 923cc? Reliability? I've got a 749R.
tarochan is offline   Reply With Quote
Old Feb 19th, 2006, 10:15 pm   #6 (permalink)
froggert's Avatar
bcm put the 100mm bore kit in. not sure what it cost exactly as i had a major service and a few other things all done at the same time. the bike's got ~5k miles and maybe 8 or 9 trackdays since it's gone in and it's run perfectly (knock on wood).
Old Feb 20th, 2006, 5:54 pm   #7 (permalink)
Jus_Livin's Avatar
Ducati performance catalog page 42 part # 96446603B. It also comes with the complete Termi exhaust and ECU.
749 bi-
Warcraft Night Elf Hunter - Doocati
Day of Defeat - Ducati 749[36thID]
Day of Defeat Source - Jus_livin[36thID]
"If you can't change those around you, then change those around you".
Jus_Livin is offline   Reply With Quote
Old Feb 21st, 2006, 3:18 pm   #8 (permalink)
froggert's Avatar
actually, the one i got was of bcm's design. not the dp one.
How loud is your exhaust? SouthsideDuc Superbikes 16 May 19th, 2006 12:07 am
exhaust wrap collateral Superbikes 43 Mar 10th, 2006 12:50 am
Remus exhaust leak... please help? kabinski Superbikes 6 Feb 13th, 2006 8:57 am
Yet another 999 exhaust thread sugarloaf11 Superbikes 8 Feb 2nd, 2006 10:07 pm
polished or satin exhaust?? kingsnake1650 Superbikes 15 Jan 29th, 2006 12:47 pm
