LED turn signal problem on 996 - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jul 5th, 2007, 10:53 am   #1 (permalink)
Hey, I am new to the Ducati world and am loving it so far. I ahve just installed LED turn signals on my 2000 996 and am having a problem getting them to work right. I have installed a Kuryakyn load equalizer on the rear signal leads and now all the signals flash when I activate the switch either direction. The tech support at the company said it had something to do with the indicator light on the dash. I was hoping you guys would know of a fix that I could still use the dash indicator. Thank you for your time
Mike
holliday06877 is offline   Reply With Quote
Old Jul 5th, 2007, 12:38 pm   #2 (permalink)
twowheelcossack's Avatar
I yanked the dash indicator bulb. Don't miss it at all...
2001 996SPS #1548
2001 748RS
2007 BMW R1200GS Adventure
"To do is to be"- Jean Paul Sartre
"To be is to do"- Aristotle
"Doobie-doobie-doo"- Frank Sinatra
twowheelcossack is offline   Reply With Quote
Old Jul 5th, 2007, 5:00 pm   #3 (permalink)
tomy2k748's Avatar
I would throw the load equalizer in the garbage and buy an electronic flasher relay. The load equalizers get hot and can cause a fire. The electronic relays always flash at the same rate no matter how many or how few lights with no heat.
2005 KTM 450SX
1997 KTM 360SX
tomy2k748 is offline   Reply With Quote
Old Jul 5th, 2007, 6:03 pm   #4 (permalink)
998Pilot's Avatar
I didn't know there were electronic relays. I installed LEDs on my rear light with an integrator and I didn't install a load equalizer for those reasons. Where can I get one?
Holiday, How do you have the rear wired? I'd make sure that nothing is connecting the two sides of the tail light in anyway.
998Pilot is offline   Reply With Quote
Old Jul 5th, 2007, 7:41 pm   #5 (permalink)
tomy2k748's Avatar
[QUOTE=998Pilot]I didn't know there were electronic relays. I installed LEDs on my rear light with an integrator and I didn't install a load equalizer for those reasons. Where can I get one?
http://cgi.ebay.com/ebaymotors/3-PIN...spagenameZWDVW
This is what I bought. I actually drilled holes in my mirrors and mounted 5mm LED's in them to get rid of the front turn signals. It has worked for 2 years now.
2005 KTM 450SX
1997 KTM 360SX
Old Jul 5th, 2007, 8:33 pm   #6 (permalink)
998Pilot's Avatar
Nice...I think I got my 90 degree LEDs from Velocity LEDs. Can you send a pic of how it's mounted?
Sorry for hijacking your thread, Holiday.
Old Jul 6th, 2007, 9:04 pm   #7 (permalink)
tomy2k748's Avatar
It fits into the position that the original flasher relay fits. Just unplug the original and plug in the new one. Way too easy. The flasher relay is mounted on the left hand side of the battery box with 3 other relays. Just take off the fairing, flip on the turn signal, feel for the clicking, and replace it.
2005 KTM 450SX
1997 KTM 360SX
Old Jul 7th, 2007, 10:42 am   #8 (permalink)
998Pilot's Avatar
Nice. I haven't looked at the existing relay long enough to see what size it is. Thanks
Old Jul 7th, 2007, 2:20 pm   #9 (permalink)
John's Avatar
Images: 15
I have the Custom Dynamic LED set up in the rear tail only. I didn't mess with the stock front turn signals and typically, they flash really fast. So, the unit above will cure this problem?
Do you know if there is an LED retrofit for the front stock signals like I did with the rears? At the time I did the rear, I couldn't find anything for the fronts. I don't want to remount the signals somewhere else. Now, if I would have known this before I bought signal light ready cf air runners, I would have seriously considered re-locating the signals in the mirrors and buying race cf air runners instead (no signal light provision). The 4 to 5 little LEDs in the mirrors is really trick looking. Damn, the more I think about it the more I want to do it, but what do I do about the stock signal light holes in the cf air runners? Oh well, stuff happens, i always disliked the stock front signal lights and I don't like flush fairing mounts as well. They seem to only look good on Asian bikes or Ducati Supersports where the signal lights mount on the fairing.
03 FLHRI Road King
03 999R #189
09 1125CR Buell (sold)
07 1100S MTS (sold)
04 999S (sold)
95 916 (sold)
01 900SS (sold)
05 Honda 600RR (sold before I crashed it)
05 Honda 600RR (full Yosh, PC, totalled it)
Ducati-Owners-Group of Sacramento region.
John is offline   Reply With Quote
Old Jul 7th, 2007, 2:51 pm   #10 (permalink)
tomy2k748's Avatar
The unit will fix any and all fast flash problems from using LED's. I couldn't find anyone that made LED signals for the front that is why I made my own.
2005 KTM 450SX
1997 KTM 360SX
Turn signal controls 17697 Sport Classic 20 Apr 30th, 2007 11:02 am
Turn Signal Eliminator Kit wcc Superbikes 2 Oct 22nd, 2006 6:13 pm
'99 900SS turn signal switch problems M5Marc Supersport 0 Sep 25th, 2006 12:32 pm
749 turn signal switch trivia: or why I hate boneheaded changes like this rustysrustyduc Superbikes 5 May 24th, 2006 4:50 pm
