2007 1098 error code - Ducati.ms - The Ultimate Ducati Forum
post #1 of 10 (permalink) Old Jun 5th, 2013, 11:22 pm Thread Starter
Hey folks,
I did a few searches and haven't really found an answer.
I picked up my bike a few weeks ago. 2007 1098 with 3900km's on it. Had a graves slip on exhaust and that's pretty much it.
Rode it home in the rain for 3.5 hours with no issues. Installed the Termi slip on (two bolts and a few springs), went for a ride and washed her up. After I washed her, It would start but then would stall out as soon as I let go of the throttle. Did that a few times and eventually it was ok. Then got an exvl code . That disappeared and all was good. Got stuck in the rain a few more times.. Then I go and start her up for a ride and I have a check engine and throwing a 10.2 code, horizontal coil error code. Bike runs like crap (feels like it's running on half the power) and has issues starting.
Any ideas??
Thanks
FRCEFED579 is offline
post #2 of 10 (permalink) Old Jun 6th, 2013, 7:19 am
efiniGTX's Avatar
Check for moisture/water in the coil connectors. Also check for corrosion in the wiring, check for small pin holes in the wiring. If it happened right after washing, that's what I would check. Not sure if you hosed down the bike or just wiped her down. Heat also breaks down the coil tube boots, which can cause spark leak in the head tubes. Before you go throwing parts at it, i would swap the coils from each head and see if the code changes. If it does then you know the coil is just bad.
07 Ducati Sport Classic
07 Ducati 1098s (sold)
efiniGTX is offline
post #3 of 10 (permalink) Old Jun 6th, 2013, 12:54 pm Thread Starter
Thanks for the info! I'll give it a shot.
post #4 of 10 (permalink) Old Jun 7th, 2013, 12:54 am
Use grease-resistant, heat inside the injection coil corrosion of moisture.
jakkrapong is offline
post #5 of 10 (permalink) Old Jun 7th, 2013, 10:36 am Thread Starter
Thanks Jakk! You replied to my thread exactly 12hours after my last post lol.
Pull the horizontal coil out last night, but didn't get to pull the plug yet.
Here's some pics. 2007 1098 error code-imageuploadedbymo-free1370619209.589377.jpg
Sent from Motorcycle.com Free App
Name:	ImageUploadedByMO Free1370619235.268991.jpg
ID:	213529   Click image for larger version
Name:	ImageUploadedByMO Free1370619288.019457.jpg
ID:	213537   Click image for larger version
Name:	ImageUploadedByMO Free1370619327.268442.jpg
post #6 of 10 (permalink) Old Jun 11th, 2013, 9:27 pm Thread Starter
Hey guys,
So I pulled the plugs and they were indeed fouled, so I swapped them out and bought a PCIII and installed that. Started her up and the error code was still there and she's still running a crap and low power.
Then I ordered a new ignition coil and installed it, and still the same issues.
Then I got to thinking... All these issues started after I installed the termi slip ons. So I put the graves slip ons back on and the bike idles a lot better, but is still running like crap.
I'm at a loss and have no clue wtf to do next. I was so excited to get this bike and it's been nothing but headaches
post #7 of 10 (permalink) Old Jun 15th, 2013, 2:27 pm Thread Starter
Here's a SITREP on my bikes issues. It ended up being the ECU. She's running like a top now!!
I'm excited to play with her now!
Thanks for the help.
Cheers
post #8 of 10 (permalink) Old Jun 15th, 2013, 11:45 pm
God to hear, not fun when chasing the issue.
JET
JETninja is offline
post #9 of 10 (permalink) Old Jun 19th, 2013, 12:47 pm Thread Starter
Ya, I was getting reallly discouraged.
I'm still trying to figure out what the hell caused it to be pooched.
Any ideas?
post #10 of 10 (permalink) Old Jun 19th, 2013, 10:26 pm
All depends on what in the ECU failed. Electronics are usually super reliable, but heat and moisture can kill them.
JET
JETninja is offline
Human Verification
r.6 error code ? Xeilaxtu HyperMotard 9 Jan 24th, 2011 9:10 pm
Error code 38.0 can HyperRyan HyperMotard 6 May 28th, 2010 7:51 am
Error code !!! sargie34 HyperMotard 10 Sep 28th, 2009 4:09 pm
1098 error code when starting Noc748 Superbikes 0 Jul 20th, 2009 4:35 pm
Error Code 6.0 - anyone know what it is? Ssssusanq Multistrada 0 Jun 19th, 2009 11:26 am
