Need help with countershaft sprocket torque value - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comGraves MotorsportsMotorcycle.com Classifieds!
Old Apr 29th, 2007, 8:35 am   #1 (permalink)
All, I need some quick help. I am trying to finish up my install of my 520 conversion on my 998. I used the article in the hall of wisdom for the install but the 998/999 motor uses a single nut to mount the sprocket.
Can some please take a look in their service manual and post the torque value. I am trying to finish this up quick so I can head out with the boys for a ride.
Thanks for the help.
Btw I have used the search and found nothing. Has anyone posted a Torque value quiock reference?
Chilton is offline   Reply With Quote
Old Apr 29th, 2007, 8:39 am   #2 (permalink)
The cuntershaft nut is 32mm. I found this torque value for the same nut size.
I assume this is correct but would like to confirm.
Originally Posted by emjay
Useful specs for swapping the front sprocket...
front sprocket retaining nut - 32mm
rear swingarm wheel nut - 30mm
chain tension adjuster bolts - 14mm
torque setting for front retaining nut - 135 ft/lbs
Thanks to the folks at Ducati Seattle for the torque info. They weren't 100% positive about the setting, but its an identical setup to one of the supersports, and 135 is the torque setting for that bike.
Old Apr 29th, 2007, 10:23 am   #3 (permalink)
JEC
JEC's Avatar
That sounds right, generally they are torqued to 100 lbs + then retained with a crush washer.
Editor, Odd-Bike.com
http://www.odd-bike.com/
'97 916
'84 Honda VF750F Interceptor (gone)
'04 Suzuki SV650 (gone)
'87 Honda VFR400R NC24 (gone)
'85 BMW K100RS (gone)
JEC is offline   Reply With Quote
Old Apr 29th, 2007, 10:31 am   #4 (permalink)
Still need your help....
anybody know the torque value for the mounting bolts for the ride height adjuster?
Old Apr 29th, 2007, 1:24 pm   #5 (permalink)
13X lb/foot is about right for the sprocket. remember to bend that little washer back on as well.
I just remember it being the same torque value as the rear axle which is also about 13X ft/lb
Danny
2005 Ducati 999
2004 Yamaha R1
2003 Yamaha R6 (Track)
m3elmo is offline   Reply With Quote
Countershaft sprocket redux Lesco Sport Touring 7 Feb 21st, 2007 2:00 pm
Front sprocket torque ma2ra Sport Classic 6 Jan 11th, 2007 10:52 am
Torque on GT tranny sprocket? SpunkytheTuna Sport Classic 4 Oct 27th, 2006 11:38 pm
Countershaft Sprocket sizes? hillclimber147 Superbikes 6 Jul 3rd, 2006 7:09 pm
Stm Quick Change Sprocket Carrier Bolt/nut Torque Setting? crashedduc Superbikes 7 Jun 12th, 2006 11:05 pm
