Dzus installation..... - Ducati.ms - The Ultimate Ducati Forum
Old Apr 18th, 2007, 11:49 am   #1 (permalink)
I cannot get the Dzus fasteners (bought from a vendor) to engage whenever the fairing goes on. Anybody had this problem ? Clip goes on and the pin will "usually" engage (seems senstive and seems to have something to do with how the clip is positioned) before the fairing goes up but then when the fairing goes up, the pin does not even come close to engaging (in any of the 8 I installed on my 748) no matter how hard I push in. It has been suggested to me that I need to "bend" it a bit.
I just said f-it and put the screws back in (which were qiute a bit longer than the pin but probably should be)
Anybody had a problem like this ?
Remus
2000 FRC Corvette
AFR/LGM/MTI/4.10
Mirek is offline   Reply With Quote
Old Apr 18th, 2007, 11:54 am   #2 (permalink)
Site Sponsor
ducatimike's Avatar
I installed the Dzus fasteners on my ST4 and had to bend the clips a bit to get them to engage with the center pin. I only had to bend them just a little to get them to work. Now all is well.
Mike
99 ST4
05 Honda 450F
01 YZ 250
www.emsduc.com
ducatimike is offline   Reply With Quote
Old Apr 18th, 2007, 11:57 am   #3 (permalink)
dnldfte's Avatar
I ordered mine form Fast by Ferrracci and have had no problems with them engaging at all. I purchased some for the bottom of the fairing. I did not put them in because I was afraid they would fall out and my fairing would do the splits. I can measure one of them and get back with you on the length of the pin.
2001 748 Biposto (Red)
2005 1000SDS Multistrada (Also Red)
dnldfte is offline   Reply With Quote
Old Apr 18th, 2007, 11:58 am   #4 (permalink)
desmofetish's Avatar
+1... Bend to fit.
Thomas Lowers
2001 748 Superbike
Charcoal Grey with Carbon highlights and Red wheels
Full Termi Exh,Surflex Slipper,GP Master Brake,GP Mater Clutch,Evo Slave,Ultimap Chip,ITG Filter,AFAM Quick change and gearing...Carbon Nose w/enlarged ports,Carbon Airbox & Runners,Carbon Mono-Tail/Custom Bi-posto Tail, Speedymoto Triple Clamp,Tec Moto Clutch Cover,L.E.D. Taillight,Custom painting...= Empty Wallet,Hungry Cat & Unfurnished Home...Thank God I'm Single!
http://www.ducati-owners-group.com/
desmofetish is offline   Reply With Quote
Old Apr 18th, 2007, 1:11 pm   #5 (permalink)
cheech's Avatar
Images: 8
they also make longer pins. what length you got? @ racebolts, they have 15mm and 16.8mm pins. i'm sure the vendor you bought them from may have the longer pins. otherwise, bend them like previous posters mentioned if they will reach.
http://www.racebolts.com/store/Dzus-Fasteners-C20.aspx
2000 748S
2000 Vertemati 503SM
cheech is offline   Reply With Quote
Old Apr 18th, 2007, 3:11 pm   #6 (permalink)
Thanks guys looks like mine are 12mm !
I got these kind (if the link shows up) from a vendor in the for sale section:
FS: Ducati Dzus Fasterns in Silver or Black
6mm D-Ring Panex Quarter Turn Fasteners
Stud Length: 12mm
Holds Material: 3.5 mm to 5.4 mm
Remus
2000 FRC Corvette
AFR/LGM/MTI/4.10
Old Apr 18th, 2007, 3:53 pm   #7 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
If you flatten the sliders to much, they wont have any spring left in them
We sell the Ducati Dzus pins with the wider slanted heads. They are about 19mm.
Old Apr 18th, 2007, 4:26 pm   #8 (permalink)
DukeDesmo's Avatar
Images: 193
My 916 was supplied new with Dzus fasteners on the fairing, including the bottom of the fairing. In 9 years they have never fallen out.
AFAIK all 916, 996, 998 and 748 (except the later 748e?) were this way and I don't know anyone who had any problems.
916 & M900.
DukeDesmo is online now   Reply With Quote
Old Apr 18th, 2007, 4:33 pm   #9 (permalink)
dnldfte's Avatar
That's really good to hear. It is a royal pain to get the shortest screwdriver I have and clamp it in a pair of channel locks to get those phillips head screws out. I may just install them this evening.
DZUS Fasteners on Bottom for 999? m3elmo Superbikes 9 Nov 16th, 2007 5:56 am
Are all the Dzus fasteners the same? rustysrustyduc Superbikes 2 Mar 29th, 2006 9:34 am
PCIII Installation vtst4s Sport Touring 2 Mar 28th, 2006 9:29 am
Good source for Dzus Fasteners? rearviewmirror Superbikes 11 Feb 14th, 2006 9:06 pm
