Ducati 996 Rev Counter Wiring - Ducati.ms - The Ultimate Ducati Forum
Old Apr 14th, 2007, 1:13 am   #1 (permalink)
I am close to completing the restoration of a wrecked Ducati 996 (insurance write-off). The wiring into the rev counter plug was ripped out and I am interested in the wiring configuration into the three pin male plug recessed into the rev counter base. Can anyone advise which pins are for what function (+, -, signal feed). The Haynes manual wiring diagrams are not helpful in this regard. I am fearful of damaging the CPU, so will not attempt to start the bike until I have addressed this wiring problem. Please can anyone assist.
AndrewP is offline   Reply With Quote
Old Apr 17th, 2007, 3:43 pm   #2 (permalink)
finding Tach wires!
Easy job....I had a 998 so wire colors may/may not be the same. In any case, don't be scared to start the bike, only three wires!
With the bike running..:
1) one wire is ground
2)use a Multimeter (DMM) and switch to DC volts. With the ignition on, bike is off- any wire that reads anywhere near 12 volts is the "positive"
3) DMM set to AC volts- start bike and probe wires one by one while revving the bike. When your readings raise/lower according to revs/throttle position, THIS IS YOUR SIGNAL.
That's it, good luck
Al
illduc is offline   Reply With Quote
Ducati Electrical Problems Explained JEC Hall of Wisdom 18 Jul 28th, 2012 4:53 pm
Stoner signs with Ducati italiapower07 Road Racing 7 Jun 20th, 2007 6:27 pm
I've Lost All Faith In Ducati LC996 Ducati Motorcycle Chat 35 Mar 30th, 2007 10:37 pm
Ducati Announces SS1000 Race-Only Model Rainman Ducati Motorcycle Chat 3 Feb 5th, 2006 6:17 am
