Apr 11th, 2007, 5:21 pm
Turning brake rotors- is it done?
Hi guys!
I was wondering, is it possible to turn down motorcycle rotors to even out the wear on them?
I'm looking for a shop in Los Angeles that can do it too, if it can be done.
Thanks!
-Dave
Apr 11th, 2007, 7:43 pm
I know of one guy that had it done and it was a total waste of time. The rotors warped even faster due to being thinner. Are you sure they are out of round? Sometimes different chemicals can glaze the rotors in spots and cause a pulsing feeling.
2005 KTM 450SX
1997 KTM 360SX
Apr 11th, 2007, 7:46 pm
what he said. moto rotors are too thin. you risk having hairline fractures or warping. i'm sure it can be done but i dunno. it maybe a saftey issue.
2000 748S
2000 Vertemati 503SM
Apr 11th, 2007, 8:02 pm
It probably can, but it's not a good idea IMHO. You'll maybe buy yourself a few rides before warpage, crackage, or worse. You're going to need to buy new rotors, so save the $100 in trying to turn them and get a nice set off a eBay. The nice thing about Ducs is that parts like the brakes fit almost every year and almost every model...320mm / 10mm offset / 6-bolt pattern (but please, check first just to be sure!). I got a beautiful pair of Brembo "snowflakes" off a Monster that were nearly brand new on eBay for $200.
Apr 11th, 2007, 8:55 pm
If they are pulsating like a poor mans ABS it's likely pad crud buildup. Take them to someone you know with a brake lathe and have him hit them with a disc hone.
See the piccys of the setup I made as mine pulsated quite badly. They work great now. I powered the drill press table as well as spinning the hone for a nice even patern.
If you take a micrometer to them you'll likely find that they are thinner near the periphery and thicker towards the inside. This coning wear is typical disc wear. As others said, don't grind them. Try the rotor hone thing first before you replace them. You can get the hone from an auto parts store for $40.
02 998 la strega bella
Reason: addition
Apr 12th, 2007, 11:19 am
if they are F'ed up, buy new ones. Don't mess about with the brakes...
Royalty Racing - St Louis' best sportbike shop
2001 748 - flat black, monoposto - For Sale?
Apr 12th, 2007, 12:03 pm
Bobaganoosh
I have used 3M Roloc Discs that have the med (red) scotch brite pad on a die grinder to resurface my rotors and it works great.
http://www.levineautoparts.com/clicherfor3m.html
Resurfaced with a red Roloc
In a Michigan State University study that ranked 34 major countries by their citizens' acceptance of the theory of evolution, the United States ranked second to last (thank you, Turkey). 39% of our adult population rejects the concept.
