Slipper clutch installation question - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Graves MotorsportsMotorcycle.com
Old Apr 10th, 2007, 5:15 am   #1 (permalink)
dutchduc900's Avatar
Images: 14
Question Slipper clutch installation question
I've just bought a 2nd hand 48T slipper clutch that looks exactly the same as the yoyodyne. Also same parts are in the package. I have already seen the installation instructions on the yoyodyne site.
Problem is that is messed up with the order of the parts (washer, spider spring and nut).
I now have 2 curved washers, 1 small curved washer and 1 big curved washer.
Question 1. What washer should be installed on the spacer, small one or big one?
Question 2. How should it be installed (as it is curved)? Inner part/diameter touching spacer or out part/diameter touching spacer?
Question 3. What's the order for washer/spider spring? I assume washer first?
Question 4. How should the washer be installed (curved again)? Inner part towards engine or towards clutch cover? Or doesn't it matter with these spring/curved washers?
Thanks for your help!!
dutchduc900 is offline   Reply With Quote
Old Apr 10th, 2007, 11:20 am   #2 (permalink)
Images: 14
The clutch is actually from TSS (Czech company). It is the same as the yoyodyne one.
Old Apr 10th, 2007, 12:09 pm   #3 (permalink)
dutchduc900,Generally the larger cone washer sits on the top of the 6 pronged spider spring and the smaller one sits on top of the spacer,both with the cone part facing towards the outer pressure plate,however is is a down load for your particular 48t.
http://www.slipperclutch.com/index.p...odukty&model=2 ....later...RS
RockStore is offline   Reply With Quote
Old Apr 10th, 2007, 4:58 pm   #4 (permalink)
Images: 14
Hi RS, thanks for the link to STM clutches. Seems that the order for the washers for the TSS is slightly different from STM. Will contact TSS directly to ask the question. There seems to be a video for installing TSS slipper clutch, anybody seen this?
Old Apr 10th, 2007, 5:07 pm   #5 (permalink)
betarace's Avatar
Location: Mayberry RFD, VA, The United States of America
google, link #2
http://www.slipperclutchs.com/montaz...el=003&lang=en
2006 Ducati 999S Nero Mono Limited Edition
1992 Honda VFR750F (reborn)
2004 Ducati 998S Final Edition
2002 Royal Enfield Bullet
1992 Honda VFR750F
1993 Suzuki GSX-R 750W
1990 Honda CBR600F
1989 Honda CBR600F
1973 Schwinn Stingray 3 Speed
betarace is offline   Reply With Quote
Old Apr 10th, 2007, 7:29 pm   #6 (permalink)
bpad1's Avatar
Here's a link to the yoydyne slipper install
http://www.yoyodyneti.com/ProductInf...oductid=T10901
'05 999R CCS#241
'08 848
[SIGPIC][/SIGPIC]
bpad1 is offline   Reply With Quote
Old Apr 11th, 2007, 3:21 am   #7 (permalink)
Images: 14
Thanks guys but this is where I messed up:
The kit includes the transmission nut, spider spring and an additional curved washer. They are attached by a cable tie in the proper order....
I don't know the proper order and I don't know if the I need to put the small washer or the big washer on top of the spacer. Probably it's all clear when I'm working on it, just want to be well prepared.
Any advise on a clutch drum holding tool?
Old May 19th, 2007, 12:49 am   #8 (permalink)
ahastings's Avatar
The small washer should go on top of the spacer before the hub.The big washer should go on the hub before the spider spring convex side out. Its purpose is a stopper for the inner hub when the slipper function pushes it out. There is no washer on top of the spider spring. Is this the clutch you have ?http://www.sliperclutchs.com/velka.p...y/002/FT11.jpg Here are the instructions with better pictures http://www.sliperclutchs.com/montaz....el=002&lang=en
Arnie
ex Ducati racer
2006 CCS MidAtlantic overall Expert #3
2007/2009 CCS MidAtlantic overall Expert #1
2010 CCS Atlantic region Overall Expert #1
2007 WERA Expert Heavyweight Twins Superbike National Champion
ahastings is offline   Reply With Quote
Clutch Question slowerthan Ducati Motorcycle Chat 3 Mar 2nd, 2007 7:34 am
Slipper clutch question Mstpolo Superbikes 4 Feb 17th, 2007 4:19 am
Ducati Dry Clutch question . . . 2ducks Ducati Motorcycle Chat 36 Jan 18th, 2007 4:40 pm
slipper clutch question . heru749 Superbikes 1 Oct 2nd, 2006 9:17 am
Noob question: Slipper Clutch...what is it and why is it important? Purspeed Superbikes 43 Mar 15th, 2006 5:54 am
