Apr 9th, 2007, 9:34 am
Pic Request: Speedymoto Clutch Covers w/ Speedymoto Pressure Plates
I'm having trouble deciding between a black 10-spoke clutch cover and the black Area 51 cover. I'd like to see how they look with a red Kukri or red Shinobi pressure plate. (I already searched the cluctch cover picture thread and found one or two matches, but would like to see more pics if people have them.)
Also, for those of you running the Kukri or Shinobi pressure plates, does rust on the OEM clutch stack show through the gaps in the pressure plate? Should I go with a solid pressure plate like the Cycle Cat for this reason?
This will be going on a red '05 749S that I just bought. I'm thinking black cover, red pressure plate, and black spring retainers... (Or maybe gold spring retainers?)
Thanks!
Apr 9th, 2007, 12:17 pm
Flavor of the Month
Pressure plate
Not really what you're looking for, but gives you an idea. Speedymoto cover and pressure plate with stainless caps and screws. I like to show it off when I can. If you want a red pressure plate, thing about going with a slipper, they're red and look awesome too.
Sam 'MF' Brandt
2000 Ducati 748
2006 Yamaha YZ450F (SCARY!)
2008 Suzuki DRZ-70 pit bike
2008 Ducati HyperMotard S
Apr 9th, 2007, 12:25 pm
here is a photo of an area 51 cover in titanium and a yellow speedymoto pressure plate(don't know the model) sorry it is not a close up.
Hope it helps.
here is a gratuitious one of the clutch cover in action
I have a flimsy half cover with a FBF pressure plate on my supersport. I think(know) the speedymoto stuff is waaayy more sturdy. No two ways about it, I would go with the Speedymoto stuff.
Apr 9th, 2007, 4:35 pm
Flow cover and Kukri pressure plate.
Apr 9th, 2007, 9:35 pm
Here's mine with the 5y clutch cover and the kukri pressure plate
749 bi-
Warcraft Night Elf Hunter - Doocati
Day of Defeat - Ducati 749[36thID]
Day of Defeat Source - Jus_livin[36thID]
"If you can't change those around you, then change those around you".
Apr 11th, 2007, 9:27 am
Thanks everyone!
Bravo, your pressure plate looks different than the Kukri Pro plate Speedymoto currently offers. Is yours an older version? I like yours better (no "teeth" 360 degrees around the outside). Those stainless caps really look nice too, maybe I should do that instead of black caps.
Jus Livin, I really like your setup too and saved that picture when I was looking through the other picture thread. Do you happen to have a shot of the bike as a whole?
From all of your pictures, it looks like you guys aren't having issues with rust on the underlying OEM clutch components? Is this true or is it just because you keep the rust cleaned off?
Anyone else have more pictures of a red 749/999 with a black Area 51 cover and a Speedymoto pressure plate? I'd like to see it from several angles before I decide...
Thanks again!
Apr 11th, 2007, 8:58 pm
I don't have alot of pictures. I hope works, if not I'll take some this weekend.
749 bi-
Apr 11th, 2007, 9:20 pm
that yellow duck is sick!! i want some gold marchs!
98 Ducati 916/955
07 bmw 335i modded all over (totaled out, rear ended by illegal!)
97 lifted tacoma w/38 inch tires and turbo'd
yfz450 traded for duck
Apr 11th, 2007, 11:09 pm
Flavor of the Month
Thanks, those rims make all the difference. I think I was lucky to get them, they're hard to find nowadays. I got them in 2005 at the same time I got my pressure plate. I had to double check it, but it is a Speedymoto. I couldn't find it on there website so maybe it is discountinued. It looks a lot like that Kukri huh? Good luck.
Sam 'MF' Brandt
2000 Ducati 748
Aug 9th, 2007, 9:11 pm
I like the stainless caps too. I think they make the whole set up look classier/more expensive. Here's mine, not installed yet.
