Master link question - Ducati.ms - The Ultimate Ducati Forum
Old Apr 5th, 2007, 9:28 am   #1 (permalink)
bpad1's Avatar
I need to swap my DiD 520 chain from my 999s to my new 999R. I have an RK 520 o-ring master link. Can't seem to find the DID locally. Will the RK work? It looks Identical.
'05 999R CCS#241
'08 848
[SIGPIC][/SIGPIC]
bpad1 is offline   Reply With Quote
Old Apr 5th, 2007, 12:04 pm   #2 (permalink)
2DucJ's Avatar
Not recommended to mix&match chain pieces.
The 2 different manufactures may design them to stretch at different rates which may cause a problem.
You don't want a $5 part causing case damage(or more) if you can avoid it.
To me it just ain't worth it
J-
07 1098s Race/Pose
05 S2R 800 For terrorizing "Racy Hi performance Bikes"
NO EXCU$E$ RACING
http://www.ducati-owners-group.com/
http://www.pacifictracktime.com/
http://gotbluemilk.com/
2DucJ is offline   Reply With Quote
Old Apr 5th, 2007, 3:59 pm   #3 (permalink)
edvin70's Avatar
I might have a spare, as I recall I used the clip type on my SS and I think I have the rivet type master still in the packing grease.
I'll look into it - its yours FOC if I find it.
2004 999S
1999 750SS BCM racer gone
Before I saw the light -
1999 ZX6R track bike
1994 CBR600F2 track bike
1993 ZX7 street
1987 FZ700 street
edvin70 is offline   Reply With Quote
Old Apr 5th, 2007, 5:09 pm   #4 (permalink)
bpad1's Avatar
Cool! thanks.
'05 999R CCS#241
'08 848
[SIGPIC][/SIGPIC]
Old Apr 5th, 2007, 6:05 pm   #5 (permalink)
galaxy's Avatar
Images: 27
Same here. If edvin can't find his, I have a DID VM520 gold, clip-type master link you can have. I'll never use it.
galaxy is offline   Reply With Quote
EK Chains and their Screw Type Master Link galaxy Ducati Motorcycle Chat 6 Jan 27th, 2007 10:30 am
Brake master cylinder question... Geof3 Superbikes 5 Jan 12th, 2007 10:33 pm
broken chain link on my 999 discovered mad Superbikes 4 Dec 31st, 2006 5:41 pm
Master link eddiemack Surveys and Polls 10 Dec 13th, 2006 11:34 am
