Cheap Bodywork Review(Pit-teck) - Ducati.ms - The Ultimate Ducati Forum
Old Feb 23rd, 2007, 7:54 am   #1 (permalink)
thatkidchris's Avatar
I know you have all seen that cheap bodywork they sell on Ebay, well I decided to buy some. I know, there are tons of horror stories about them but I can do some fiberglass and bodywork so I figure I can handle any problems. Im gonna use this thread to document what I think about them and the install over the next week or two. It may take awhile as I am a 1 1/2 time student and work 40+ hours a week now.
Here is the exact listing I bought
http://cgi.ebay.com/ebaymotors/ws/eB...m=130077262691
First impressions
Shipping times on these things are amazing. I paid for them about 3pm on a friday and they were at my door when I got home from school at 2pm on Monday. The box is huge and packed FULL of packing peanuts. No damage from shipping would ever happen to these things.
Out of the box I get my first look at them. They are heavier than other brands but the stories I hear about them being extermly brittle just isnt true for mine. It may be because the Duc has alot more flat surfaces than the average asian bike. They bend and flex fairly well for the price I paid. They do, on the other hand uses oriented strand cloth instead of the normal weave that Hotbodies, Godfather, etc use.
Primer they have on them is cheap but sprayed fairly well. There are no thin parts or runs so final prep should be pretty easy. The upper fairing was compressed a little but when pushed onto the fairing bracket it expaned with no cracking. I may also have to add a little glass on the upper arond the screen on one side as it looks like the trimmer got a little happy and cut a tad bit much out. Shouldnt be too hard for me as I have fiberglass experience.
The side panels kinda amazed me. I expected them to be extremly wavy, as most ducs with fiberglass bodywork seem to have wavy side panels, but they were amazingy smooth. On the other hand the edges werent trimed exactly straight but 20 mins and an sanding block will fix that.
The seat unit! What can I say. The seat unit is probably the worst part in the kit. It is slightly warped(should be able to fix that). But more concerning is that where it meets the airbox and tank doesnt fit that well. This seat flares out a little too much and may take a little modification around that area.
I will deffinetly need advice from you great guys on fitting the belly pan. Ive never used one so Im not exactly sure on how its mounted. Any pictures or instructions?
More to come as I began to fit and mount these. Pictures too.
thatkidchris is offline   Reply With Quote
Old Feb 23rd, 2007, 9:56 am   #2 (permalink)
MV_999R's Avatar
Good info.
Thanks for taking the time to share it
MV_999R is offline   Reply With Quote
Old Feb 23rd, 2007, 10:46 am   #3 (permalink)
Bugatti's Avatar
Damn this is cheap! Around $300 for a full kit.
I'll keep an eye on this thread, may get some myself if you give it the thumbs up.
'03 999 Testastretta
'95 M3 Dakar
Bugatti is offline   Reply With Quote
Old Feb 23rd, 2007, 1:10 pm   #4 (permalink)
Pyrate's Avatar
On the belly pan, I mounted my uppers first (they are separate like the stock stuff) and then lined up the belly pan and marked the holes to drill. I had to work with it a bit (mostly by sanding) to make sure it lined up the way I wanted. Its mostly right but could have been a bit tighter in spots, I just ran out of room.
Did you get any additional brackets for the kit to mount to? Mine came with two for the rear which without would have been a struggle to mount the pan without them.
Of course this is all on a 749 so not sure how much help it will be.
04 749 Track Bike
06 ST3
Pyrate is offline   Reply With Quote
Old Feb 24th, 2007, 8:47 am   #5 (permalink)
level7's Avatar
Can you tell me if the solo seat has hardware already attached (probably wishful thinking) to mount to the bike? Where did you get the hardware if not?
998 Monoposto - The final form of a legend
"Each day is a gift, have fun" - 11 year old boy who died of cancer
level7 is offline   Reply With Quote
Old Feb 24th, 2007, 9:27 am   #6 (permalink)
Pyrate's Avatar
The body work I purchased came with it, it was the Ducati Corse stuff I bought used. I am not real crazy about the quality or finish of the fiberglass however it fit pretty good.
You may be able to purchase the brackets from a dealer, they are basically Z brackets that will accept a female DZUS that attaches with two rivets. One bracket is a little longer than the other. On the right side it mounts to the rear brake master cylinder with existing bolts and holes. On the left it mounts just under the front sprocket, again to existing holes.
They keep the rear of the belly pan out and away from the chain/swingarm.
04 749 Track Bike
06 ST3
Old Feb 24th, 2007, 11:49 am   #7 (permalink)
04749s's Avatar
That's what I'm thinking !! But still even for the cost it's not bad ....
2001 ST2
998sFE
04749s is offline   Reply With Quote
Old Feb 24th, 2007, 11:53 pm   #8 (permalink)
S4one's Avatar
I just bought the same fairings for my zx6r. I have to admit that they are good for the price... One thing forsure is that im not going to paint them because I do not think it is worth it. Good for starting race fairings!
06 749 Dark
Ohlins damper
Motowheels vented clutch cover
Motowheels gas cap
Full floating rotors
Pitbull spools
Cycle Cat GP shifter
Ducati Performace 41t rear sporket
Monoposta conversion
Remus slip on
Speedymoto SS springs and caps
Silverstar bulb
S4one is offline   Reply With Quote
Old Nov 25th, 2008, 4:15 pm   #9 (permalink)
how to mount bodywork?
I've got the same body work. And experienced the same thing:
- Overall, parts are reasonable for $300
- Shipping was great
- Upper was compress and had to be "stretched" to fit my bracket
But I have an additional question...
I'm mounting mine up to a 748 I plan to race next year.
The side panels I have the 4 Dzus per side (two under the upper, two from the frame tabs).
But how the heck to I secure the belly pan?
And, how do I keep the side from "twisting in the wind"?
I can connect the belly pan to the bottom of each side panel.
But that would just leave the sides and belly "hanging" from the 4 Dzus at the top of the side panels.
There needs to be something to holds (at least) the leading edge of the side panels to the bike (stock bodywork has a V-shaped piece for that).
But even with that, it seems like the weight of the belly pan should be secure to something besides the bottom of the side panels.
I can try to post pics if that will help.
Please - any advice will be great appreciated.
Thanks,
Rick
sick_ducati_vw is offline   Reply With Quote
New Mirrors on... Bodywork off BellaCorse Sport Classic 7 Oct 29th, 2006 1:28 pm
Carbon bodywork fitment twowheelcossack Superbikes 9 Oct 5th, 2006 6:55 pm
