Interested in Ti bolts for front brake rotors but have a few questions;
I know Ti is lighter than steel but is it as strong? I have heard that some titanium parts are prone to failure under use, any info?.
What's the difference between Titanium Gr5 and 6Al-4V Titanium Alloy - which is best, strongest, most suitable etc.
Does Ti 'Gall' to Aluminium unless fitted with anti-seize Grease? or can Loctite be used and removed without issue?
On a related issue I see that according to 'Desmotimes' website 'older' Ducati's used M8 x 20mm rotor bolts and that from 2000 they used M8 x 15mm, presuambly they were changed to reduce weight but was anything changed in the wheel? I ask because my 1998 916 had the shorter bolts.
Concerning bolt length, is there any reason why I should not be using the shorter bolt in an aftermarket Marchesini 10-spoke (5y) forged Aluminium wheel?
Any advice?
