749/999 - Ducati.ms - The Ultimate Ducati Forum
Old Jan 22nd, 2007, 11:40 am   #1 (permalink)
749/999
Are the 2005/2006 749 and 999 exhaust systems exactly the same ? Are they interchangeable ? Is the only difference between the two the engine size ?
Cheers
" Stay low and keep Movin "
Keyboard is offline   Reply With Quote
Old Jan 22nd, 2007, 11:43 am   #2 (permalink)
MV_999R's Avatar
Cheers
- Yes (just not the ECU)
- Yes
- Not sure if the injection and electronics are exaclty the same, but maybe they are.
MV_999R is offline   Reply With Quote
Old Jan 22nd, 2007, 11:57 am   #3 (permalink)
well done
MV 999R you are a good man my friend, cheers from Canada !!!
Old Jan 22nd, 2007, 1:31 pm   #4 (permalink)
MV_999R's Avatar
Np. You're welcome.
But i just want to add that if you're talking about a full system then you have to consider that the 749Dark still have the old swingarm and that i'm not sure if the base 749 and the 749S have the "copabassa" engine and if they don't, then a full system from a 05 999 for instance won't fit.
Old Jan 22nd, 2007, 8:01 pm   #5 (permalink)
galaxy's Avatar
Images: 27
'06 Darks have the new swing arm.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Jan 22nd, 2007, 8:07 pm   #6 (permalink)
Dark_Daddy's Avatar
Images: 10
Tru dat mofo!
Chris
2006 749 Tricolore FOR SALE
Dark_Daddy is offline   Reply With Quote
Old Jan 22nd, 2007, 8:10 pm   #7 (permalink)
kaos's Avatar
your forgeting about the 05 999 change to deep sump.the long pipe is bent to clear.thus a 749 pipe will not fit on a 05 999 or earlier ''s and r''999
giallo 949- impractical,irrational,irresistible ,09 gasgas raga,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Jan 22nd, 2007, 8:19 pm   #8 (permalink)
So are the 2005 999 and 2005 749 the same, do they not both have the deep sump, so you could interchange the exhaust ?
Old Jan 22nd, 2007, 11:52 pm   #9 (permalink)
D/S or Non D/S:
All 749's, regardless of year, are NOT deep sump (d/s).
The only exception is the 749R, which is d/s engine, all years.
All 999R's are d/s.
'03 and '04 999 are NOT d/s.
'05 and '06 999 are d/s.
Not sure about the 999S, maybe someone can chime in.
Swingarms:
2003 - All bikes have old (cast) swingarm
2004 - Only 749R and 999R receive new (box section) swingarm
2005 - All bikes get new swingarm, except 749 Dark
2006 - 749 Dark receives new swingarm
For whatever combination exhaust change you are going to do, you have to make sure that the ENGINE (d/s or not) and SWINGARM (cast or box-section) match.
angie-r is offline   Reply With Quote
Old Jan 23rd, 2007, 4:45 am   #10 (permalink)
MV_999R's Avatar
I did forget it in my first post but then i warned about it
Originally Posted by MV_999R
....and that i'm not sure if the base 749 and the 749S have the "copabassa" engine and if they don't, then a full system from a 05 999 for instance won't fit.
Copabassa means deep sump.
749/999 OEM Shock Valving stover Superbikes 0 Dec 28th, 2006 5:15 pm
Ever paint 749/999 mirrors? rustysrustyduc Superbikes 2 Apr 11th, 2006 9:04 pm
