Dyno run correction method - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Dec 26th, 2006, 2:52 pm   #1 (permalink)
Lifetime Premium
Images: 20
I recently had my bike dyno'd and the data given to me weren't corrected for altitude (or temperature or humidity). I did a little googling and found the following link:
http://www.wahiduddin.net/calc/calc_cf.htm
that explains the SAE method for correcting a dyno run for altitude, temperature, and humidity. Thought this might be of use to someone.
I've also attached my (corrected) dyno run along with a comparison of what Ducati had on their web site. A few observations:
1) There is a big discrepancy above 7500 rpm. I thought the Ducati data would be crank not rear wheel but if that is the case why is my torque as good or better between 5200 and 7500 rpm? I'm also wondering if the Ducati data includes ram air effect?
2) It looks like for my run they could have gotten closer to the rev limiter. The last point looks like it was beginning to shut off but that is a very low rev limit. I know I've hit it just above 11000 rpm, not 10200 as shown on the graph.
3) Looks like the fueling could be improved a lot between 3000 and 5200 rpm.
4) Peak hp is 104 at 7290 rpm for my dyno (rear wheel) run vs 118 at 10700 rpm for the Ducati data (crank?).
My bike is stock as far as fueling/exhaust is concerned. Dynojet dyno for my bike.
Any feedback would be welcome.
'06 749s
mbohn is offline   Reply With Quote
Old Dec 27th, 2006, 4:46 pm   #2 (permalink)
Lifetime Premium
Images: 20
Any body?
'06 749s
Old Dec 27th, 2006, 10:24 pm   #3 (permalink)
OldBaldy's Avatar
I'm afraid it's almost meaningless to try to compare posted manufacturer HP numbers against a specific bike's dyno run.
Dynos vary so much in HP output that making direct comparisons is mostly a fruitless exercise - especially when one is comparing dynos of potentially different makes, models and correction factors and assumed frictional losses (yes, the Duc numbers are calculate numbers with assumed frictional losses added back to simulate crank HP numbers - a ridiculous concept in itself)
I wouldn't lose any sleep of the differences you;re seeing - rather compare your own bike against others on that same dyno, using the same correction factor, or use it as a baseline for any tuning you do. That's where the real value is, IMO.
Still, an interesting question, in terms of the difference in the shape of the curves!
Old Baldy / WWBO #451
Ducati 996
Yamaha WR250
Kawasaki KDX200
DucsUnlimited.com
OldBaldy is offline   Reply With Quote
Old Jul 2nd, 2007, 8:25 pm   #4 (permalink)
Lifetime Premium
Images: 20
Let me ask a different question on this situation.
Would I benefit from dyno tuning with my stock exhaust system? I don't plan to go to aftermarket exhaust in the near future.
As I look at the torque curve, the dip between 4000-5000 rpm doesn't matter on the track. I spend all my time between 6000 and redline and there the torque curve is pretty smooth.
But I've been told by one tuner that Ducatis run rich in that range and that tuning can bring out more power. I'd hate to think I'm missing something that could be brought out by a good tuner.
Thoughts?
'06 749s
Old Jul 3rd, 2007, 1:00 am   #5 (permalink)
Nove-R's Avatar
Originally Posted by mbohn
Thoughts?
Cost/ benefit.
Streetfighers are built, not bought.
'05 999R
'00 955i/ GSXR1000 Streetfigher
'06 ZX-636 race bike
'08 KLR-685
'99 KZ-1000 Police Special
'84 VF500F Interceptor
999 or 998 Streetfighter (next build)
Nove-R is offline   Reply With Quote
Old Jul 3rd, 2007, 9:37 am   #6 (permalink)
Lifetime Premium
Images: 20
Originally Posted by Nove-R
Cost/ benefit.
Ok, but I need to get a handle on the benefit. I can determine cost pretty easily.
'06 749s
Old Jul 3rd, 2007, 12:12 pm   #7 (permalink)
749Seddie's Avatar
Thoughts?
My personal opinion......I would have the bike dynoed by a certified Dynojet dealer. If you are not going to add an exhaust right now, at least add a PCIII. This device will help smooth out the power curve, and you may gain a little horsepower. The main benefit would be to get the cylinders running equal, and have better throttle response. This will be noticable on the track coming out of corners, etc. The horsepower number that Ducati is quoting is at the crank(I think). Most 749S that I have seen dynoed have come in around 100 to 105 RWHP.
Eddie
04 749S/920 (track bike)
07 KTM 300 (off road)
01 996TT 620RWHP
749Seddie is offline   Reply With Quote
Old Jul 3rd, 2007, 12:49 pm   #8 (permalink)
Lifetime Premium
Images: 20
With altitude correction I'm at 99 and 105, right on the money.
Man, I sure would like to feel this bike at sea level! Another 20 hp !!
'06 749s
Old Jul 3rd, 2007, 3:30 pm   #9 (permalink)
Nove-R's Avatar
The stock ECU is detuned slightly to accomodate sound and pollution restrictions. Adding a PCIII and getting it tuned on a Dyno will maybe add a few HP at best. If it idles roughly or stumbles at certain RPM and those problems are fuel related, then you can probably fix them.
Considering that the retail price for the PCIII plus dyno time for the tune will cost you over $600.00, it doesn't make any sense to me.
If you modify the engine somehow or add a larger/ no catalytic pipe or do air filter mods, then you need the PCIII to correct the air/ fuel that will get thrown out of whack.
There seems to be this belief that adding a Power Commander by itself will add more power (it's probably the name ). Not really. You mod other parts of the bike- exhaust, cams, airbox/ filter, etc, and those mods add horsepower. The PCIII makes those mods play nice with your bike. After the tune, you'll make more HP, but not because of the PCIII, rather because the mods that are now working properly with the bike, as they were designed.
'05 999R
'08 KLR-685
Old Jul 3rd, 2007, 4:42 pm   #10 (permalink)
749Seddie's Avatar
I wasn't claiming big horsepower gains....see my post! I was saying to use the power commander to smooth the power out, thus creating faster, easier exits from corners(better throttle response). He stated that he wasn't going to get an exhaust anytime soon, so this would be a noticable improvement on the track. It seemed like he wanted to get the fuel right. If it were me I would get a pipe,filters, and PCIII to start with. Not sure of his budget
Eddie
01 996TT 620RWHP
another dyno question blade625CT Ducati Motorcycle Chat 6 Oct 17th, 2006 7:15 pm
Dyno... rjcduc Supersport 1 Jul 14th, 2006 7:55 am
My 748SP on the dyno.. amullo Superbikes 4 May 3rd, 2006 1:38 am
PCIII Without Dyno brianmdavis Superbikes 21 Feb 13th, 2006 7:51 pm
