Battery tender overcharging? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 60 (permalink) Old Nov 2nd, 2012, 12:26 am Thread Starter
bmarcinczyk14's Avatar
So I just got a new Deltran battery tender and hooked it up to my 848 via the quick connect. It went to green flashing light pretty fast and couple hours later the green light was still flashing. I thought this couldn't be right considering I fully charged a motorcycle battery with this same tender and it didn't even take that long. I put on another Deltran tender I have laying around thinking maybe its a faulty unit and this one did the same thing with the green flashing light. I hooked up aligator clips via the quick connect on the bike and checked the voltage and it showed 14 volts, so it seems the tender is overcharing the battery but for whatever reason it doesn't want to go into "maintain mode" with the solid green light. I was reading around and read someone say that a tender should charge a battery up to around 14.7 volts before it goes into maintain mode? What do you guys think, should I just leave the damn thing on for a day and see if it ever goes into maintain mode?
'09 848 -- '05 636 Track bike -- '10 370z Sport Package
bmarcinczyk14 is offline
post #2 of 60 (permalink) Old Nov 2nd, 2012, 12:28 am
Nobody
Chuckracer's Avatar
Images: 2
Ayup.
Chuckracer is offline
post #3 of 60 (permalink) Old Nov 2nd, 2012, 12:32 am Thread Starter
Originally Posted by Chuckracer View Post
Ayup.
And if the battery blows you'll cover the new battery and fairings? Lol, I'll take that as you being sarcastic.
How long should it stay in the green flashing light mode? Wouldn't 2 hours be too long?
post #4 of 60 (permalink) Old Nov 2nd, 2012, 12:42 am
Temporary greeter
Wonway's Avatar
Originally Posted by chuckracer View Post
ayup.
+1
1994 888 LTD #61 DVT
2014 KTM Adventure R with duct tape mod v1.0
Ducati.ms ECM photos
Wonway is offline
post #5 of 60 (permalink) Old Nov 2nd, 2012, 12:43 am
KrustyKruser's Avatar
The flashing green means the battery is about 80% capacity. The tender is charging at 750mah so it will take a while to get to capacity. Make sure you don't have a drain on the battery or left the parking light on with the ignition. You should be ok leaving it connected.
KrustyKruser is offline
post #6 of 60 (permalink) Old Nov 2nd, 2012, 12:47 am Thread Starter
It was at 14 volts with the green light still flashing though
EDIT: im going ti just leave it on overnight and see if its solid green by the time i get up for work
Sent from my SCH-I535 using Motorcycle.com Free App
post #7 of 60 (permalink) Old Nov 2nd, 2012, 3:00 am
ZDM
Super Senior Poster
Buy a BatteryMINDER by VDC Electronics and be done with it. My Deltran Battery Tendor never fully charged my YUASA......I found (only around %80 +/- charged when checked by a pro instrument). The BatteryMINDER charged the battery completely then maintains it.
ZDM is offline
post #8 of 60 (permalink) Old Nov 2nd, 2012, 7:44 am Thread Starter
So rhis moening i check and the green light is still flashing and its still hoovering around 14 volts, wtf?
post #9 of 60 (permalink) Old Nov 2nd, 2012, 8:08 am
Secret Squirrel's Avatar
I think you're fine. At a slow charge rate of 750mah it could take several days to peak to full charge. Slow charging at low amperage is a good thing for a battery. A comparison would be having a full size empty swimming pool and trying to fill it by peeing in it. That's going to take a while. They make the peak charge rate slow because it's better for the battery. It takes time though.
2011 Ducati Streetfighter S -- 2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
Secret Squirrel is offline
post #10 of 60 (permalink) Old Nov 2nd, 2012, 8:47 am Thread Starter
But it was around 14 volts when I disconnected the tender and checked the voltage. Wouldn't it be around 12 volts fully charged?
Human Verification
Battery's so dead, Battery Tender will not charge it... Tag Sport Classic 11 May 29th, 2011 4:31 pm
Battery Tender: Which to get? cDiddy Sport Classic 14 Oct 27th, 2010 11:50 am
Battery Tender Mr.13 Monster 2 Oct 19th, 2009 9:04 am
Battery tender????? kersey78 Supersport 10 Sep 19th, 2008 12:25 pm
Battery Tender Nomore76 Sport Touring 10 Mar 6th, 2008 7:15 am
