Lamb 22.2 heater error. - Ducati.ms - The Ultimate Ducati Forum
Old Jul 17th, 2012, 6:43 pm   #1 (permalink)
Question Lamb 22.2 heater error.
How do I fix this error? The bike started up before and then randomly just shot up this error. When the bike started up, I had the lambda sensor disconnected. After I connected the sensor I still kept getting the error. Maybe I connected it to the wrong connector?! Please help. Thank you.
vitalik is offline   Reply With Quote
Old Jul 18th, 2012, 8:53 am   #2 (permalink)
lambda sensor dont like being run without the heater connected, they are the most fragile sensor on the bike! having said that them old Bosch 4 wires arnt to bad.
on alot of race bikes its normal to put new 4.9's in every weekend!
it could be that the sensor is shot, could be that the ecu needs a hard reset.
disconnect both battery terminals and short the loom ends together for a few seconds, this will discharge the capacitors in the ecu and should clear any faults.
Lumley32 is offline   Reply With Quote
Old Jul 19th, 2012, 3:53 pm   #3 (permalink)
I'll try resetting it. Thanks for the feedback.
Old Jan 20th, 2013, 8:07 pm   #4 (permalink)
How did you resolve this issue? I'm having the exact same issue under similar circumstances.
Thanks,
Dana
DZircher is offline   Reply With Quote
Lamb cel Fast_Momo HyperMotard 3 Jul 25th, 2010 2:21 pm
Engine Oil Heater Gareth Sport Classic 9 Mar 3rd, 2010 6:57 pm
LAMB 6.1 Error - After restart it went away...still take to shop? Dana HyperMotard 1 Aug 8th, 2009 4:53 pm
