Paint bubbles on tank - 749R - Ducati.ms - The Ultimate Ducati Forum
Old Nov 24th, 2006, 6:23 pm   #1 (permalink)
palooka's Avatar
Howdy.
My 749R has recently developed some paint bubbles around the tank breather. I suspect that fuel is seeping under the paint around the breather hole and it seems to be getting worse. I also suspect that it is a design flaw as later model xx9 series bikes seem to have the breather hole slightly more riased.
Has anyone else encountered the same problem? If so, what was the fix?
I am thinking of having a thick washer welded to the top of the tank before I get the paint re-sprayed.
Cheers
Palooka
04 S4R
04 749R
palooka is offline   Reply With Quote
Old Nov 24th, 2006, 8:18 pm   #2 (permalink)
kaos's Avatar
pics? gas usually softens paint till it peels off,bubbles and pimples are from moisture under the topcoat
giallo 949- impractical,irrational,irresistible ,13 txt pro 280,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Nov 27th, 2006, 3:38 pm   #3 (permalink)
palooka's Avatar
Can someone please post a closeup photo of the breather vent on the top of the tank on an 06 model 999 or 749? I'm looking to have my tank modified before being re-painted and believe that the breather vent on the recent models is different to earlier ones.
Thanks
Palooka
04 S4R
04 749R
Old Nov 27th, 2006, 3:46 pm   #4 (permalink)
MV_999R's Avatar
Don't have that problem on mine and it's the first time i hear about it.
BTW 999 gas tanks don't have a breather on the top of the tank.
MV_999R is offline   Reply With Quote
Old Nov 27th, 2006, 4:03 pm   #5 (permalink)
sounds like something that SHOULD be covered under warrenty. you should not be the one that has to pay for a repaint
Danny
2005 Ducati 999
2004 Yamaha R1
2003 Yamaha R6 (Track)
m3elmo is offline   Reply With Quote
Old Nov 27th, 2006, 4:22 pm   #6 (permalink)
palooka's Avatar
It's an 04 model so it is out of warranty, but I will pay the dealer a visit soon to see if they will come to the party on a claim.
04 S4R
04 749R
Repairing a leaking SS tank Rainman Supersport 68 May 20th, 2013 3:32 pm
