1198 SP Clutch Grab - Ducati.ms - The Ultimate Ducati Forum
Old May 22nd, 2012, 7:43 am   #1 (permalink)
1198 SP Clutch Grab
Hi, I am experiencing some issues with my slipper clutch.
When i release the clutch from a standing start in 1st gear the clutch will suddenly grab with no warning at all. I have to quickly pull the clutch handle in so not to stall or have such a sudden jerk.
Annoying as I have also just spent $850 AUD to replace the clutch basket and plates.
What could be wrong!!
sam perth city is offline   Reply With Quote
Old May 22nd, 2012, 9:29 am   #2 (permalink)
Nothing, really. That's pretty common with a dry slipper. Two things that can help: 1. Induce a little bit of air into the circuit which will soften the bite. By doing that you'll need to bleed it more often to keep it the way you want. 2. Clutch pack...I got a Barnett pack which includes a beveled steel plate. This plate acts like a bit of an internal spring and that also softens the bite.
If you find any other solutions...shout out!
Buckeye is offline   Reply With Quote
Old May 22nd, 2012, 9:40 am   #3 (permalink)
Old Fast Guy
TOP_DUC's Avatar
Sounds like the plate stack is out of order and/or missing the cone-shaped plate, and/or the friction plates are contaminated. What brand of plates/basket did you buy? If not the DP OEM unit parts, you may have issues with the slipper action...
My OEM 1198SP slipper is smooth as glass.
`11 Ducati 1198SP SBK Red; w/Termi full exh; Redline flash + PC-5 tune; Sargent; Shift-tech, EVR(airbox), CDT, & BST(wheels) carbon; FBF 14/39 QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf; lots of titanium... 182whp/105wtq
`12 Ducati 1100SP EVO Hyper CORSE; w/Termi exh; Ducshop Stacks; Redline flash + PC-5 tune; FBF 14/41 QC; Shift-tech, CDT, Star, & BST(wheels) carbon; R&G; SF bars; ProGrip; Antigravity; SC Project; Ducabike; Duc Perf slipper; screen, str damper, seat, cat delete; lots of titanium... 94whp/73wtq
`12 Aprilia RSV4 Factory w/Akra Titanium exh w/Race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL; Antigravity; Zero Gravity; AF1 Carbon; lots of titanium... 181whp/83wtq
TOP_DUC is offline   Reply With Quote
Old May 22nd, 2012, 9:53 am   #4 (permalink)
Hi,
I came across a tread here that suggest applying the lithium grease on the clutch plate. I am using the normal clutch system and encounter grabby clutch on my 996. Tried the grease method and now my clutch work flawlessly. Other had review it work for slipper too, you may like to try.
1999 996 Biposto
rockoil is offline   Reply With Quote
Old May 22nd, 2012, 6:17 pm   #5 (permalink)
Old Cafe Racer in Northern Oz
Images: 95
Grabby, shreiking, clutch and how I cured it
davy.j is offline   Reply With Quote
High RPM Clutch grab windsurfnut Monster 5 Aug 6th, 2009 1:47 pm
Grab Rail Rainbow StreetFighter 3 Jul 21st, 2009 12:04 am
St2 Rear Grab delta1098 Sport Touring 2 Apr 11th, 2009 6:27 pm
620 Clutch Grab? countfunkula Monster 9 Mar 11th, 2009 7:24 am
GT Grab Rail GreyDuck Sport Classic 3 Jan 23rd, 2007 1:46 am
