Thanks for the info NCRick, is the 21/75 spring equivalent to the spring in my stock Biposto Showa shock?, which I'm told is a 75 (or is that 0.75?) and, I'm told, pretty much ideal for my weight (around 205-210lbs). FYI the bike is a 916 biposto with some minor weight loss; CF parts, Mono seat & Marchesini 10 spoke wheels - I guess the only significant weight loss is due to the wheels, street ridden and with Showa forks with 10 (1.0?) rate springs.
Would you advise that I setup the ride height & sag exactly as per the Showa to get the same results or is there a different recommended setting? due to the shock being a different unit.
As for the other shock without any numbers, the spring is the same shade of yellow as the one with the writing and actually measures very slightly thicker - 21/75 spring measures around 10.8mm whilst the other measures around 11mm - I don't know what (if anything) this relates to?
At this point I'm looking to see which shock to use (probably the 21/75), I'll sell the other one once I've sorted which way I'm going but was curious to know exactly what I've bought and which, if any, is more suitable for my bike.
Another thing - The shock with the 21/75 spring came from an '02 bike with only 7,000 miles on it, do you think it would need servicing? (oil/gas etc).
Thanks again
