ducati 748 chain and sprockets - Ducati.ms - The Ultimate Ducati Forum
Old Feb 28th, 2012, 11:55 am   #1 (permalink)
I just hit 12k on my 01 ducati 748 and its time to see the shop. I'm also in need of a new chain and since I'm at it wanted to change the sprockets also. My question is what have you guys found to be a great set up in sprockets or should I just keep stock tooth. All comments are welcome!!
Duc28312 is offline   Reply With Quote
Old Feb 28th, 2012, 12:14 pm   #2 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
I like the 14/41 on the 748.
I'd use these sprockets:
DRIVEN Light Front Sprocket 520/14T
SUPERSPROX "Stealth" 520 Sprocket: 748-998
the stealth is a one piece design that is a little less expensive than going with a seperate quick change carrier and sprocket. It has steel teeth that will last a long time.
Old Feb 28th, 2012, 5:01 pm   #3 (permalink)
How big of a difference is a 14/40 from a 14/41. Plan on doing some track days so wanted something for the road and track.
Old Feb 28th, 2012, 5:10 pm   #4 (permalink)
Havin a Time
Chuckracer's Avatar
Images: 2
Everything You Ever Wanted To Know About Gearing...And Then Some:
Sprocket/Gearing Recommendations
S.O.D.O.M.
Old Feb 29th, 2012, 1:21 am   #5 (permalink)
Super Duper Member
CptFunnypants's Avatar
With the 520-41 rear, that'd make the gearing shorter right? So at say 70mph in 6th you'd be pulling around 5800 instead of the 5200 you get with the stock 38, but you'de get there quicker....more torquey. What effect does that have on the shaft bearing over time? Wouldn't it be better to keep the stock rear and jump a tooth on the front sprock? I'm a newb, so I'm just curious.
Sent from my HTC Evo 4G
Kansas City, KS
1998 Ducati 748 Mono
"Before you criticize me, walk a mile in my shoes. That way, when you criticize me you're a mile away and you have my shoes" - Me (No really, I just said that. ROFL. Yes, I am now actually on the floor rolling around laughing like a deranged idiot.)
CptFunnypants is offline   Reply With Quote
Old Feb 29th, 2012, 7:00 am   #6 (permalink)
Old Cafe Racer in Northern Oz
Images: 95
Only way he can go on the front sprocket is up to 15t and that raises the gearing.
I run 14/42 and she is a ball tearer, fast as all hell up to 125mph. but 14/41 would be a better setup overall like moto said.
I need the lower gearing to drive up a 1 in 3 ramp at home once I'm finished playing and don't need autobahn top speeds anyway.
davy.j is offline   Reply With Quote
Old Feb 29th, 2012, 12:52 pm   #7 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Not that big of a difference - but it is noticeable.
If you want more flexibility in gearing, consider a quick change set up.
The carrier is more expensive but replacement sprockets are relatively less expensive.
Something like this:
DRIVEN Quick Change Sprocket Carrier: 748
or
AFAM Quick Change Sprocket Carrier - Early
and this
DRIVEN Quick Change Sprocket: S2R / S4R / M796 / M1100 / MTS1000 / MTS1100 / MH900E / 748-998 / 848 / Hyper
or
AFAM Quick Change Rear Sprocket 520
Old Feb 29th, 2012, 4:16 pm   #8 (permalink)
Ceij's Avatar
One of the first modifications I did to my 748 was to change the ratio from the stock 14/38 to 14/40 (as recommended by Shazaam's table that Chuckracer linked to).
As Shazaam states:
"Ducati decides what front and rear sprocket sizes to install on each model depending upon a number of objectives and constraints. The standard gear ratio is a compromise that considers fuel economy, performance, and the need to meet environmental laws that limit exhaust gas emissions."
I decided on the 14/40 ratio after discussing it with Steve at ECS (European Cycle Services) and based on my riding style and objectives (street only).
ECS installed a 520 D.I.D. gold chain with a Supersprox Stealth 40-tooth rear (since I don't use the 748 for the track) and a 14 tooth front.
I think it is the most significant change I made to my 748. Adding two teeth to the rear made a huge difference. I feel it is what should be on the 748 if noise emissions and such weren't an issue.
Se é facile per te, io parlo Italiano.
La mia Anatra: 1997 Ducati 748/853 with many modifications.
Ceij is online now   Reply With Quote
Old Feb 29th, 2012, 7:14 pm   #9 (permalink)
2000 748R
hirschey155's Avatar
I'm running 14/40 on my 748R. It works much better in town than the stock gearing but did not limit the top end too much.
hirschey155 is offline   Reply With Quote
Old Feb 29th, 2012, 9:12 pm   #10 (permalink)
I run a quick change on the rear and 40-42 depending on my mood (and the track). The quick change is a little more expensive but cheaper sprockets as Moto said. 14T on the front. I used to run 14/40 when it was a street bike.
mia748sp is online now   Reply With Quote
chain & sprockets sofadriver Sport Touring 8 Jun 15th, 2011 7:52 pm
ducati 996 sps chain and sprockets johnnie27 Superbikes 5 Feb 27th, 2011 5:50 am
New chain and sprockets for an ST3 Ducit Sport Touring 9 May 8th, 2008 8:11 pm
Chain and Sprockets for 916 LuvDog Superbikes 0 Dec 4th, 2006 8:16 pm
Chain and sprockets MGN54 Superbikes 4 Nov 2nd, 2006 7:21 pm
