Will '03 749S forks fit '05 749 Dark? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Graves Motorsports
Old Feb 6th, 2012, 9:06 am   #1 (permalink)
4corsa's Avatar
Looking at buying a pair of gold nitrided forks from an 03 749S for my 2005 749 Dark. Please let me know if there are any complications that would keep it from being a direct swap (brake mounts, etc.). Thank you!!
4corsa is offline   Reply With Quote
Old Feb 6th, 2012, 6:42 pm   #2 (permalink)
kaos's Avatar
yes they are a straight bolt on
giallo 949- impractical,irrational,irresistible ,09 gasgas raga,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Feb 9th, 2012, 8:06 am   #3 (permalink)
4corsa's Avatar
I was just told by MarkBilt suspension tech that the S forks are bigger diameter and would require that i also swap out my triple trees.
Old Feb 9th, 2012, 8:27 am   #4 (permalink)
kaos's Avatar
well then markbilt doesn't know what hes talking about.749s models come with showa (smaller triples),999s comes with ohilns.(larger triple)
Old Mar 2nd, 2012, 4:22 am   #5 (permalink)
Won't he need the axle from a 'S' model seeing that the dark has rebound and compression separated between the forks?
virgilbg is offline   Reply With Quote
Old Mar 2nd, 2012, 5:54 am   #6 (permalink)
They are a direct replacement. Both are 53mm top & bottom....axel brakes everything......no problem making the switch!
Viper1 is offline   Reply With Quote
Old Mar 2nd, 2012, 6:23 am   #7 (permalink)
Per the Ducati Omaha site the axle part numbers are different.
81910431A for the 749/S
81910431B for the 749D
The 's' has rebound and compression on each fork meaning that you have an adjustment that goes through the axle. While the dark seperates them rebound on one compression on the other...
Old Mar 2nd, 2012, 8:56 am   #8 (permalink)
kaos's Avatar
yes all the superbike axles have a hole drilled in them (except darks) for screwdriver access.but really nobody adjusts often so you don't ''need'' that specific axle,you could just adjust with the axle out
04 749S forks, as new ALephart Parts and Accessories 0 Dec 26th, 2010 9:32 pm
will 04 749 dark ecu work on 03 749s porker99 Superbikes 5 Jul 19th, 2010 3:43 pm
749s Dark??? Noir Superbikes 17 Jun 24th, 2009 1:10 pm
Shot in the dark-- know any tuners who need a set of forks to develop a kit? colacin HyperMotard 2 Apr 21st, 2009 9:12 pm
749 Dark front forks dfaber Superbikes 9 Jan 12th, 2007 8:22 pm
