999R Forged Al wheels vs Aftermarket forged Al Marchesini wheel weights - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Graves Motorsports
Old Feb 3rd, 2012, 12:31 pm   #1 (permalink)
2fasst's Avatar
I replaced my 999R forged aluminum Marchesini wheels for 'aftermarket' forged Aluminum Marchesini wheels. I wanted to changed things around a bit. I didn't want to go with forged magnesium as I didn't want to deal of deteriorating magnesium over time. The Marchesini distributor told me to xray magnesium wheels yearly after 5 years. I decided against BST as I didn't like the 'open' look of the 5-spokes. So I went with Gold wheels..will see how they turn out.
Here's the weights using a digital bathroom scale:
FRONT
OEM Forged 999R,no rotors/bolts. Spacer included: 7.2 LBS
Aftermarket forged Al, no rotors/bolts. Spacer included: 8.2 LBS
REAR
OEM Forged 999R rear. No brake rotor. With cush drive/carrier: 15.2 LBS
Aftermarket, no brake rotor, with Cush drive/carrier: 13.8 LBS
The rear wheel combination of the 999R weigh more due to the sprocket carrier.
The aftermarket Marchesini sprocket carrier is a lot lighter.
2005 R1-Marchesini, Graves Full System, Custom map, Ohlins R&T, Ohlins Shock, STM Slipper, PVM 20x18, BrakeTech iron rotors, Sato rear sets.
2006 999R Xerox-Leo Vince Full System, Custom map, Brembo Masters, Sato rear sets
2007 GSXR750 Track-Ohlins 25mm cartrigdes. TTX shock, Yoshi TRC Slipon, Custom map, Woodcraft engine covers, Sato rear sets, Brembo master
2fasst is online now   Reply With Quote
Old Feb 3rd, 2012, 1:37 pm   #2 (permalink)
ZDM
Super Senior Poster
I wouldn't say the aftermarket Marchesini wheels are superior to OEM but they better quality and lighter. I found your front wheel weight comparison odd as when I weighed OEM forged vs. aftermarket I found the rear lighter as you did as well as the front. I don't recall the exact weight, but they weren't much lighter. In comparison the aftermarket is really quite a bit nicer then the OEM stuff. Much cleaner rear carrier, top quality spacers. I have the 2011 spec hoops which are really nice!
I would doubt you could feel the diff between a magnesium and aluminum forged. I actually like my cast hoops vs the forged as the forged hoops are darty on street surfaces. On a pure track surface I understand, but in hindsight I would have passed.
ZDM is offline   Reply With Quote
Old Feb 3rd, 2012, 2:10 pm   #3 (permalink)
2fasst's Avatar
I was surprising disappointed that my aftermarket FRONT wheel weighs 1 LB more then OEM, so I remeasured 3 times. The spokes of the OEM wheels are much thinner, so I'm guessing this where some of the weight savings are from. You're right that the rear setup is much cleaner on the aftermarket. The carrier, especially is much nicer.
Old Feb 3rd, 2012, 2:45 pm   #4 (permalink)
2fasst's Avatar
999R Forged Aluminum Marchesini wheels 2fasst Parts and Accessories 7 Jan 25th, 2012 7:28 pm
FS: 999R Marchesini Forged wheels WCMoto Parts and Accessories 12 Sep 28th, 2011 5:50 am
Aftermarket Forged Aluminum Marchesini VS OE forged Marchesisni bohalranipol Superbikes 10 Dec 11th, 2010 10:50 am
fs 999R marchesini forged wheels mr-x Parts and Accessories 5 Nov 29th, 2010 4:45 pm
Does the 999R come with forged magnesium or forged aluminum wheels? 2fasst Superbikes 16 Jan 9th, 2007 10:24 am
