Feb 3rd, 2012, 11:23 am
749 fan removal question for track bike
I was looking at my cooling fans the other day and I'm thinking that I would get better airflow through the rad if I removed one. I'm pretty sure the fan on the right side (timing belt side) is the high temp fan and that would be the one I'd take off. This is on a track only 749. I've never had even the low temp fan come on so I'm thinking that the high one can be removed. It just looks to me that better airflow through the rad would happen if the fan and shroud wasnt there.
Tried to search but didn't find much. Anyone do this on a track bike and if so are there any check engine lights? And is the high temp fan on the right side?
Feb 3rd, 2012, 11:35 am
why not rewire to stay constantly on?
Feb 3rd, 2012, 11:49 am
Cause at 200km/hr the fan isnt helping its blocking
Feb 3rd, 2012, 12:02 pm
A friend of mine pulled his for the reasons you stated wit no issues.
I pulled mine and got a check engine light. I got sick of looking at the light and put them back in. That and I smashed my LCD and would not know if it was over heating. I put them back in and they are not running when I pull off the track. If I let it idle for a bit after coming off they will kick on. That tells be the bike is at proper temp while on track and the fans are not hurting anything.
Feb 3rd, 2012, 12:31 pm
i took both fans off my old track-only 749/924 with no issues. the check engine light does stay on, though.
1098s, m620, m750
Feb 3rd, 2012, 12:36 pm
Just jump the two wires with a resistor to keep the light off. You can take a multimeter and measure the resistance of the fan.
Resistors are identified by resistance and power rating. Resistance you measure, power rating you calculate using the basic Ohm laws.
Power (W) = Volts (V) ^2 / Resistance (R)
V of course is 14
Take the power from above and get something greater than that. RadioShack has a good assortment.
I've done it many times with cars when I removed stuff...
Btw, on my 999S the right side is the high temp...
Feb 3rd, 2012, 12:38 pm
removed on my 749S race bike
Feb 3rd, 2012, 1:39 pm
V of course is 14
Thanks my man!!! Thats what I'll do. Just to confirm I can buy a resistor of say XX ohms and just solder that to the connector? Anyone know off hand what kind of wattage that fan might be? Cant be much.
Say 20W fan
20W = (14V x 14V) / R
20W = 196/R
R = 196/20
R = 9.8
R = 10 ohms so get a 10 ohm or greater resistor???
Feb 3rd, 2012, 1:44 pm
Say 20W fan
20W = 196/R
R = 196/20
R = 9.8
Well, you got it backward... You won't be able to measure power with the multimeter: that's what you calculate. You measure resistance.
You might not find a resistor with the exact same resistance as what you measure. Get something closer, either way (the ECU actually accept a range of resistance before triggering the CEL). The power rating is what you want to get greater otherwise the resistor will overheat and burn.
I wouldn't solder it if I were you, just in case you ever want to go back. First try just to fit the prongs of the resistor into the plugs and ensure it works...
Feb 3rd, 2012, 2:05 pm
If you have a performance map in your ECU you can change the settings so it won't throw any errors.
This is the way it works on my bike (05 999).
Moto Morini Corsaro Veloce
Ducati 1198 (Race)
Ducati 999 (Race)
Ducati 999
Benelli 1130 TNT CR
Benelli 1130 TNT
ST4S
Ducati 900 SS
Ducati 900 SS(track)
Ducati 996 (Track)
BMW 1100 RS (x2)
