Feb 1st, 2012, 4:30 pm
New 998 owner - Questions!
Hi all,
I purchased my first Ducati last September (2011) and it was a 998 with about 2,000 miles. Did a few maintenance items myself (oil change, brake fluid flush, and clutch fluid flush..) as well as fixing a problem (leaking quick disconnect, changing from the plastic connector to metal ones) with the help of this forum (just from searching old threads). Also had the dealer replaced the fuel filter and timing belts (since it is a '02, it has been awhile.. !). I have put maybe about 500 miles on it so far and it has been great to get back on 2-wheels.
A quick question for you experts: The bike came w/ a set of Termi cans. I am guessing it is a half system (? Not sure.. how do I tell?). Does that mean it also has the DP ECU already? (I think the 1/2 system comes w/ that, right?) Again, where do I look to tell?
Would it makes sense to install a Power Commander and have it tuned on dyno? I am not a racer or anything, but if it would make it "better", I don't mind spending a little bit money. Or it would not be needed if one has the DP ECU already?
Thanks in advance!
Feb 1st, 2012, 4:53 pm
Remove the right fairing and look at the ecu, it should have a part number. Run the part number through a search engine or maybe this sight and it will tell you which ecu you have. That is how I figured mine out  .
t_bare
1 Ducati = Ducatista
2 Ducatis = Mechanic
2002 Ducati 998 Faster Banana!!!
2000 Ducati ST4
2000 KTM 300 EXC
1998 KX250
Feb 1st, 2012, 5:43 pm
Thanks.. sorry for the noob question.. where is the ECU located?
Feb 1st, 2012, 6:06 pm
The Finder
ECU is behind the right side fairing.
How does the bike run? Strong and more importantly--smoothly at all RPM and loads? If so, then no real need to spend the money. That said, timing the cams and doing a custom individual cylinder map will net some results. Even more if you set the squish and give it a little bump in compression.
2001 Ducati 996 R
1998 Ducati 916 SPS #909
2001 Ducati 996 track bike
1971 Honda CB450 cafe racer
1989 Honda NSR250 MC18/derestricted
2001 Derbi GPR 75
2000 Ducati 996 SPS #1134(sold)
2001 Ducati 996 Monoposto(sold)
1998 Ducati 748 (sold)
1999 Ducati Monster 900 (sold)
1995 Ducati 916 (sold)
1997 Suzuki TL1000s (sold)
1994 Honda VFR750 (sold)
1988 Yamaha FZR1000 (sold)
1990 Suzuki Katana 600 (sold)
1986 Yamaha Radian 600 (sold)
1985 Kawasaki GPz750 (sold)
1983 Suzuki GS450E (sold)
Feb 1st, 2012, 7:10 pm
Power Commanders are nice for the tweakability. How does it generally run? If it's ok below 3000, I'd likely leave it alone. Bear in mind that the PC for the 998 really does nothing under ~3500 rpm. If you do it, it'll run a bit stronger and likely pickup 3-4 hp.
02 998 la strega bella
Feb 1st, 2012, 7:14 pm
Thank you for your quick response.
I think the bike runs well, although I really have no reference to compare to. My last bike was a '98 GSX-R600 and it was stolen in '04. So it has been a long time since I was on 2-wheel. And the Gixxer was not EFi.
I think it is relatively smooth other than maybe the transition from off to on throttle.
Feb 1st, 2012, 7:17 pm
Here's a pic of the bike.. !
Feb 1st, 2012, 7:22 pm
The Finder
Oh, you didn't mention it was yellow. PCIII won't work.
2001 Ducati 996 R
2001 Derbi GPR 75
Feb 1st, 2012, 7:23 pm
Can you point out where is the ECU on this pic? Sorry for the noob question..
Feb 1st, 2012, 7:24 pm
Isn't yellow the fastest color?!
