cracked abs fairing - Ducati.ms - The Ultimate Ducati Forum
Old Feb 1st, 2012, 12:20 pm   #1 (permalink)
cracked abs fairing
i just found a crack in a new to me set of abs fairings. i'm wondering if there's a cheap/easy/effective way to either repair the crack (ideally) or prevent further crack growth.
any constructive (no comments about the relative quality of abs vs composite, i wanted an inexpensive set and got one!) inputs wouid be appreciated!
cracked abs fairing-cowling-crack-abs2.jpg   cracked abs fairing-cowling-crack-abs.jpg
2011 1198sp
2011 multistrada 1200s
2009 696 (my wife's lil monster)
2006 bmw r1200gs (gone but not forgotten)
bartman314 is offline   Reply With Quote
Old Feb 1st, 2012, 3:52 pm   #2 (permalink)
Go to any big boxstore and in the plumbing section, buy ABS solvent cement. Make sure it's for ABS only, not PVC and not transition cement. Prep the crack from the back side by creating a very very small groove along the length of the crack. Use an artists or fine tipped paint brush to run a small amount of the ABS glue in to the groove that you made. Allow the backside of the fairing to rest horizontally so the glue can rest while it hardens without running or blobing. Use ventilation during the application the glue melts brain cells like salt melts ice. repair will be cured after 24hrs.
Good luck
ae0022 is offline   Reply With Quote
Cracked side fairing on PS Smart1 Sport Classic 7 Jul 16th, 2009 3:03 pm
Cracked Fairing TMILLER Superbikes 0 Oct 27th, 2008 12:58 pm
Cracked the Fairing with my Knee hawc Superbikes 12 Aug 26th, 2008 8:29 am
Cracked Fairing RDuc3 Sport Touring 6 Jun 19th, 2008 3:19 pm
Cracked fairing RAMM241 Sport Touring 2 Apr 13th, 2006 12:29 am
