1098 Gearing Fitment - Ducati.ms - The Ultimate Ducati Forum
Old Jan 31st, 2012, 7:01 pm   #1 (permalink)
Have a 1098 currently with a 520 setup and 15/38. I am trying to get to ratios that are in between 15/37 and 15/39. What I would like to run is 16/40 or 16/41, but have been told that this will have fitment issues such as the sprocket will contact the swingarm or the chain will rub the top of the runner where it goes through the swingarm. Not sure if the countershaft being a 16 will cause the chain to rub on the cases? I realize that I will have to change the chain most likely to add the links to get in the adjustment range, but mostly concerned that the above mentioned problems will occur. Has anyone tried this setup before? Thanks in advance. - Jim
jimne245 is offline   Reply With Quote
1098 hyper wheel fitment FrozenInCND HyperMotard 0 Dec 20th, 2010 9:52 am
1098 Gearing change FastMatt Superbikes 4 Jan 26th, 2010 5:44 am
Will fitment 02 620 g1186 Monster 3 Oct 3rd, 2009 10:32 pm
1098 max top speed with proper gearing? Ricu Superbikes 48 Jan 22nd, 2009 2:36 pm
front 999 bst fitment issue on 1098 forks scottrwilliams Superbikes 1 Jun 19th, 2008 8:28 pm
