Hi Gang,
I'd like to swap some 848 (53mm) forks onto my 1997 748 over the winter.
Have any of you guys done this swap before?
I tried to search the archives, but the search terms '848' and '748' don't help much.
I did manage to find two similar threads, but not exactly what I want to do:
999 showa to radial mount kit? Can 848 showas fit?
1098/1198 Ohlins forks in a 916
Let's assume for a moment that I've already got the 848 forks, calipers, and brake line.
- Which axle would be used, 748 or 848?
- Can I reuse my 748 wheel?
- Can I reuse my 748 rotors?
- Will my 748 fender bolt up?
- Will the speedometer still work?
Are there any other details I'm forgetting?
Thanks in advance for any help you can provide.....
