1098 Termi slip on question? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsSportbikeTrackGearMotorcycle.com Classifieds!
Old Jan 29th, 2012, 9:10 am   #1 (permalink)
Hi I have recently purchased a 1098 and it already has the Termi slipon and ecu installed. I have the bike torn down to do some cleaning and have noticed that there is a vacum line that comes off of the throttle bodies and goes into a tee that has been capped off. There is also a spot on the servo for vacum that has been capped off. Is that part of the instalation for the slipons? And if so do the cables have to still be hook up? I know the servo motor has to stay for the ecu code purpose, but i have heard that the exhaust valve stays open with this kit any info would help.....
Thanks
Bonzo17 is offline   Reply With Quote
Old Jan 29th, 2012, 10:12 am   #2 (permalink)
Not sure what you're talking about, but that is not part of installing any slip-ons.
2010 Ducati 1198
2007 Kawasaki ZZR600 (sold)
avaipan2 is offline   Reply With Quote
Old Jan 29th, 2012, 3:41 pm   #3 (permalink)
The vaccum lines and t's and capping off sounds like someone took off the carbon evap cannister or whatever its called.
denali804 is offline   Reply With Quote
Old Jan 29th, 2012, 7:41 pm   #4 (permalink)
bullseye!
'08 848, Red (Termi's.. not much else needed)
'01 ST4, Blue (Arrow Pipes, Ohlins Rear Shock, Alum. Swingarm, DD Headlight, CRG Levers, CycleCat Risers)
'02 Monster 750S i.e., Senna (Remus Pipes, Rizoma Triples & Clip-ons / Belt Covers/ Mirrors/ Sprocket Cover)
ducati_750 is offline   Reply With Quote
F/S Termi CF 848/1098/1198 Slip-On kit & 70mm DP ECU Anarchy919 Parts and Accessories 13 Aug 29th, 2011 11:47 am
Need Termi Slip Ons for 1098 Alpha Superbikes 6 Mar 3rd, 2011 1:29 pm
848 termi slip-on and chip in 1098 inyang Superbikes 19 Sep 15th, 2008 1:25 pm
