Had a similar question about a cam and the numbers stamped on them. Seems there is a top secret ducati index some where. Some one seemed to have some numbers. Just saying because what the manual gives as a PN is not what is on the dang cam. If we have this much trouble just getting that number I can not imaging getting lift, duration and overlap numbers which you could verify either install or V block it and use a dial indicator to verify numbers. Also important would be all the other dimensions. I just do not know that much about the ducati cams. Frustration for sure. Good luck though.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
