06 999s rebuild help - Ducati.ms - The Ultimate Ducati Forum
Old Jan 28th, 2012, 1:08 pm   #1 (permalink)
HI All im building a project with a hand full of HS kids and we have to take the motor compleatly appart and split the case(due to the fact that upper motor mount has brokenand needs to be welded) any way im doing this at my home (I lerned the hard way with my first motorcycle club project)
ANy way I was wondering if any one knows of a complete gasket and seal kit avable for the 06 S motor? or do I have to buy everything alacart? Any and all help would be greatly appricated also any part#'s would be great! On another note does anyone have a light weight flywheel forsale for the 999S? I also think i rember that BCM used to turn down the OEM flywheel's on their 853 motors We can do that at the shop so if any one has any magic weight #'s for a 999S motor that may work also since my budget is just about spent untill I sell last years project so the less$$ the better.
Ill post some pics up soon of the engine teardown on our website.
niskygarage look under the quack quack project
Thanks in advance
RichieD the shop teacher
richied is offline   Reply With Quote
Old Jan 28th, 2012, 4:42 pm   #2 (permalink)
ZDM
Super Senior Poster
I don't believe that there is a gasket "kit" for the 999 as most of the cases are assembled with Threebond gasket sealer. So you'll only need to purchase the head, base, loads of different color O-rings, etc. Regarding the flywheel. BCM is no longer in biz, I believe Fast by Ferracci or Ducshop can lighten a stock rotor-cost is approx. $75 IIRC.
ZDM is offline   Reply With Quote
Old Jan 28th, 2012, 11:29 pm   #3 (permalink)
safetyfish's Avatar
If your shop at school has the abillity to weld damaged engine cases then taking a standard flywheel and lighten it should not be a problem for your pupils.
There is plenty of insight and info in the Hall of Wisdom (Hall of Wisdom - Ducati.ms - The Ultimate Ducati Forum)
I had a look at the pictures, that is not a 2006 model bike btw. That is more like a circa 2003 model bike.
All the best with the project
SF
999R
998 Bayliss
safetyfish is offline   Reply With Quote
Old Jan 29th, 2012, 7:32 am   #4 (permalink)
Thanks for the info on the flywheel Ill look their! I was hoping that some one would put the weights of flywheels out! As for the bike you are right the bike is an 03 but I just picked up an 06 S motor to replace the standard motor which I dont have pic's on the sight of yet I figured it would be cheeper to buy this motor than try to budget tweek a stock 999 motor. and since I got the motor for less than Ive seen s cams go for I went with it. I am hoping I can recoop the money by selling the stock motor as soon as we know the S motor is ok.
Again thanks for the info and the insite
Richie
Old Jan 29th, 2012, 12:25 pm   #5 (permalink)
porschespinner's Avatar
original 999S Flywheel is 2245g (at least in 2004 model)
I am running a Durbahn Flywheel 254g. Runs great on the track, never used it on the street.
06 999s rebuild help-999s-oem-flywheel.jpg   06 999s rebuild help-999-umbau-524.jpg
2004 999s Track/Race only
1992 750ss Cafe Racer
1991 750ss (in long term storage)
1993 900ss (in long term storage)
porschespinner is online now   Reply With Quote
Old Jan 31st, 2012, 6:10 am   #6 (permalink)
WOW that is one hell of a differance! Is your enging modified or is it stock? just wondering. IM guessing that will be to light for the street. Ill need some rotational mass to keep the thing from stalling but it would be fun for about 1 hr on my ride to work
Thanks for the info and pics it helps a lot
Old Jan 31st, 2012, 8:39 am   #7 (permalink)
dzucati999r's Avatar
I was wondering if you've given any thought as to how you will torque that alternater nut. You'll hear all sorts of hair brained ideas, but you must stabilize it with some sort of holding tool. I bought an over priced ducati tool but I'm sure you could check out a photo of this tool and make one. Pro Italia has a catalog of complete tools for the 999 series.
73 CB500
79 KDX400
80 KZ1000ltd
84 GPZ900
74 Z1
89 Bumble Beemer
2005 999R ??????
dzucati999r is offline   Reply With Quote
Old Jan 31st, 2012, 11:18 am   #8 (permalink)
ZDM
Super Senior Poster
I'm running a Nichols flywheel on my 2003 999 base. It's the lightest on the market, some say it's too light. However I've found no downside to having one. My 999 idles, fine, no stalling issues, etc. It does have a marked improvement in throttle response, revs a bit quicker than stock.
If your going to run a 2005+ engine in a 2003/04' 999 you'll need to replace the stock or if it has one, Termignoni horizontal pipe as it won't fit around the deep sump properly. Other than the deep sump the only diff is the cams and IIRC the cam timing pickup. But you'll most definitely need the proper tool to remove the flywheel. I used a clutch holding tool and a high torque impact gun which whipped the nut right off. But I was told thats a no, no too.
Good luck with your project!
Old Jan 31st, 2012, 12:23 pm   #9 (permalink)
Jyrki's Avatar
I have that same Durbahn flywheel in my engine and it works just fine. Haven't regretted buying it.
'04 924S
Jyrki is offline   Reply With Quote
Old Feb 1st, 2012, 5:02 pm   #10 (permalink)
I removed mine with a makeshift holder and an impact tool as well, but then there's reassembly time. 270 Newton meters is nothing to sneez at. One guy suggested that I jam a penny somewhere in the gear chain. I suggest tool #88713.2036
73 CB500
79 KDX400
80 KZ1000ltd
84 GPZ900
74 Z1
89 Bumble Beemer
2005 999R ??????
Swingarm swap out question: 05 999S to 04 999S Warp Racer Superbikes 9 Jul 16th, 2011 1:03 pm
05 999 Rebuild Desi999 Superbikes 7 May 1st, 2009 3:39 pm
How much to rebuild a 999S Ohlins shock Greg_S Superbikes 0 Mar 17th, 2009 12:02 pm
966 SS rebuild bruntr Supersport 8 Nov 12th, 2007 2:34 am
996 rebuild. DrDesmo Superbikes 19 May 28th, 2007 10:46 pm
