Jan 27th, 2012, 10:55 pm
How to switch from map 1 to map 2 on a microtec ecu?
Ok, I installed the microtec ecu in my Desmosedici, set the TPS, the bike works reasonably well (but is somewhat rich). That is with a "base" map, the guys at EVR who sold it to me also installed a Ducshop map in the ecu as map #2 which should work with my corse exhaust system. But how to switch from one map to the other? There is a switch which needs to be fitted into the wiring harness? Does an existing handlebar switch change the map? I have tried all and found no solution to this, nor can I figure out how to switch the map using the laptop. Any ideas?
Jan 28th, 2012, 3:17 am
Hi John,
I think is like my ducati microtec, with the bike running you press the starter button.
Watch the dash and you will see the rev rise and the limiter light on as you press the button.
748R '02 - Fantastic Bike
748SP '97(sold)
900SS '94(sold)
Cagiva Prima R '95 (sold)
Mar 6th, 2012, 4:58 pm
Originally Posted by desmo_pt
Hi John,
I just installed mine. How can I tell if I'm on map 1 or map 2?
2005 R1-Marchesini, Graves Full System, Custom map, Ohlins R&T, Ohlins Shock, STM Slipper, PVM 20x18, BrakeTech iron rotors, Sato rear sets.
2006 999R Xerox-Leo Vince Full System, Custom map, Brembo Masters, Sato rear sets
2007 GSXR750 Track-Ohlins 25mm cartrigdes. TTX shock, Yoshi TRC Slipon, Custom map, Woodcraft engine covers, Sato rear sets, Brembo master
Mar 7th, 2012, 2:19 am
I have the Microtec on my 848. You change the map by holding the starter switch in for 3-5 seconds and as another person said you wait till the rev-limiter light flashes a couple times and then extinguishes.
You won't know what map your on unless you plug your laptop into the ECU while it's running--you can swich maps using the laptop as well, by clicking on the "map" button. For this reason I try not to use the "kill switch" because if you forget that it's engaged you'll inadvertently switch the map.
As far as the maps go, I think each bike needs a custom map. I have tried the two maps that came with my ECU and they don't fit the bike very well--both run too rich in my opinion. Although I haven't had it on a dyno, on the track I notice big dips in the powerband.
If you can find someone to do a custom map let me know because I'm looking for one as well.
"I have been through some terrible things in my life, some of which actually happened."
Mark Twain
2008 848
2002 CBR F4i (SOLD)
Mar 7th, 2012, 3:18 am
You press the starter button:
If the bike is in MAP 1 – Dash RPM will move to 8000rpm and activate the over rev warning light for 3 seconds, then back to normal RPM use.
If the bike is in MAP 2 – Dash RPM will move to 4000rpm and activate the over rev warning light for 2 seconds, then back to normal RPM use.
It isn't the best way, but is what it can be done with the 1098 dash.
748SP '97(sold)
900SS '94(sold)
Mar 7th, 2012, 10:42 am
On my 999r, with the oem ECU I just press the starter button once to start the engine as the computer does the rest.
With the Microtec ECU, it works more like a traditional starter button now where I have to hold the start button until the engine starts. (which I like better anyway)
Mar 10th, 2012, 8:22 am
4k indicates map 1.
8k indicates map 2.
Not sure on desmo.
