Stem seal - Ducati.ms - The Ultimate Ducati Forum
Old Jan 27th, 2012, 12:59 pm   #1 (permalink)
Stem seal
My 02 996 smokes when warmed up, particularly when taking off from the lights.
An older friend (60+)! thinks its a valve stem seal gone as the smoke is not there on steadyish throttle openings.
If this is so, and I have asked around a fair bit - can the stem seals be changed without taking the head off?
Anyone have an exploded drawing of the valve, guide, seal arrangement in the head?
manga is offline   Reply With Quote
Old Jan 27th, 2012, 2:40 pm   #2 (permalink)
SP3
SP3's Avatar
Images: 6
You could do it in the bike. But, it won't be any fun.
1991 851 SP3
1966 250 Monza
1999 Moster 900 City (not so much City anymore)
SP3 is offline   Reply With Quote
Old Jan 27th, 2012, 2:47 pm   #3 (permalink)
I'd have to agree with SP3 - while it may be possible, overall you'd save a lot of work and remove the heads rather than try to replace them with the heads on.
916duc is offline   Reply With Quote
Old Jan 27th, 2012, 2:55 pm   #4 (permalink)
Dmitry's Avatar
I think it's an easy job to do it in the bike once the cams and rockers are out, but before you go replacing them I'd make sure they are the cause of your smoking problem. I damaged mine while doing the valve shims (screw driver slipped couple times) but decided not to replace them this time around, not willing to wait 3+ weeks for them to be shipped form Italy. I can smell oil, it burns little between oil changes, but there is no smoke.
Dmitry is offline   Reply With Quote
Old Jan 28th, 2012, 9:47 am   #5 (permalink)
kaos's Avatar
Fwiw I would doubt its valve seals,best to do. Leak down test.
giallo 949- impractical,irrational,irresistible ,09 gasgas raga,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Jan 28th, 2012, 11:36 am   #6 (permalink)
I would agree . Oil on start up then gone = valve oil seals (usually)
Oil from traffic light starts = rings (usually)
06 999R
ducati2242 is online now   Reply With Quote
Old Jan 28th, 2012, 11:38 am   #7 (permalink)
DukeDesmo's Avatar
Images: 144
It might technically be possible to do with the heads on but would be much easier to take the heads off, especially with the rear cylinder exhaust valves.
Give you chance to clean and reseat the valves, check the guides and rings while you're there.
FWIW I doubt it's just the valve seals...
916 & M944 'project'.
DukeDesmo is online now   Reply With Quote
Old Jan 28th, 2012, 12:16 pm   #8 (permalink)
Cheers, what I will do is pull the plugs 1st to see if I can tell which cylinder is giving me trouble. Then a compression check (need to get a tester 1st).
Then I guess its engine out to check that cylinder.
Sigh - will have to be in the summer as its too cold in my garage in winter.
Or I could sell the bike on and get something else......
Old Jan 28th, 2012, 8:38 pm   #9 (permalink)
Dmitry's Avatar
I think your biggest mistake is to assume that you seeing oil smoke, sometimes rich running engine will puff grey smoke that is mistaken for oil.
second mistake is trying to fix it before checking your oil consumption, if you loosing less than a quart in 1000 miles, I'd leave it alone. All engines burn oil, some more than others, unless it's becoming a problem (plugs fowling up, having to add oil every week) ride it as is, you can relax knowing that everything is well lubricated.
First check oil level, than oil consumption, then plugs and compression (and oil breather) in that order. Once you have some results you will have a complete picture and someone here with more knowledge then me will advise you on the best course of action form there.
Also post a thread with a better title, like "996 smoking" and you will get better response, could be other reason why you seeing smoke. Pretty sure 996's have some fueling issues that cause rich condition from take off.
Old Jan 29th, 2012, 9:53 am   #10 (permalink)
Thank you that is reassuring advice.
Steering stem nut mrturbozxj Parts and Accessories 0 Apr 16th, 2011 11:35 am
999 stem diameter TAftonomos Superbikes 2 Jan 30th, 2009 8:18 pm
Question on valve stem oil seal malakai Multistrada 3 Jul 26th, 2008 12:31 pm
S2R steering stem vs. S4R steering stem KrashBandit Monster 0 Apr 29th, 2008 2:23 pm
Valve Stem Nut? bavarian3 Sport Classic 2 Jun 22nd, 2007 6:53 am
