Desmoquattro Throttle - Ducati.ms - The Ultimate Ducati Forum
Old Jan 24th, 2012, 9:19 pm   #1 (permalink)
Is the only way to give the old quattros a quick throttle response to install a new cam on the throttle body assembly? Can't go with the Yamaha throttle tube?
If so, how is the Electron, or whatever it's called? Most posts regarding this cam are old and I'm looking for some current or long-term use feedback.
Do I need to adjust the throttle position (voltage) if I get a new cam?
the manual life of an animal
Namor is offline   Reply With Quote
Old Jan 24th, 2012, 9:29 pm   #2 (permalink)
94CobraR's Avatar
Images: 5
I've been using that cam for a couple of years. It helps but it's not a drastic difference. Still have to release and regroup sometimes. The billet throttle that desmotimes sells looks better.
And no, you don't have to reset anything. Maybe some cable slack,
Sent from my Motorcycle iPad app
Jimmy
Go Gators
www.g8rduc.com
94CobraR is offline   Reply With Quote
Old Jan 24th, 2012, 9:48 pm   #3 (permalink)
Precisely what I wanted to hear, thanks.
Idle/throttle help, on a trip, bad full throttle, sound clip Namor Superbikes 9 Nov 24th, 2011 3:45 pm
TPO Beast Desmoquattro.... DukeDesmo Superbikes 0 Nov 19th, 2010 4:58 am
848 TB in a desmoquattro desmo_pt Superbikes 12 Sep 20th, 2009 1:47 am
Desmoquattro and Testaretta doctormigz Superbikes 17 Sep 18th, 2007 3:04 pm
Can you put a 999 oil cooler on a desmoquattro? JEC Superbikes 0 Oct 26th, 2006 11:05 am
