Originally Posted by moriwaki
hi all
anyone got some base suspension settings for my new bike?
its standard ohlins front and rear
im about 15st with leathers and will set her up for fast road
any advice to get a good base would be appreciated
cheers
Yes
From the 998S FE Owners Manual
"Page 27 - Front Fork Adjusters
STANDARD Factory settings is as follows:
compression 10 clicks
rebound 12 clicks
Max setting range for softest damping adjustment is 24 clicks (rebound) and 28 clicks (compression).
To change the preload of the spring inside each fork leg, turn the hex adjuster with a 22m hexagon wrench - Factory setting is 10mm.
Important
Adjust both fork legs to same settings"
"Page 28 - Shock Absorber Adjusters
The shock absorber has outer ajusters that enable you to adjust your motorcycle to the load. The adjuster (1) located on the left side, on the connection holding the shock absorber to the swingarm, controls rebound damping.
The adjuster (2) on the shock absorber expansion reservoir controls compression damping.
Turn the adjusters (1 and 2) clockwise to increase damping, anticlockwise to reduce it.
STANDARD SETTING:
turn the adjusters (1 and 2) all the way in (clockwise) then slacken them 14 clicks.
Two ring nuts (3) located on the top section of the shock absorber are used to adjust the outer spring preload.
Turn upper ring nut to change spring preload.
Then tighten or slacken the lower ring to increase or decrease spring preload as required. Once adjusted tighten the upper ring nut."
There are warnings too!! If you want those let me now - enough typing now!
