1098 Clutch lever stuck - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jan 20th, 2012, 11:55 am   #1 (permalink)
aswad's Avatar
Exclamation 1098 Clutch lever stuck
background: i have always find it not easy to get to neutral or shift to 3rd gear on my 1098 track bike ...
today on the track it became so hard to get the 3rd and then all of sudden clutch lever is getting stuck not going in all the way in and returning very slowly ... i tried bleeding but i cant get it to work as it feels like there is something stopping the lever half way so i cant fully pull the clutch!!
any ideas what could be wrong?
1098 Superbike 07 (Track)
X-Rides :
Ducati Monster S4R 07
Honda CBR1000RR 05
Harley v-rod muscle 09
Kawasaki ZX10R 09
aswad is offline   Reply With Quote
Old Jan 20th, 2012, 12:17 pm   #2 (permalink)
Sounds like the Push Rod may be bent. Remove the Clutch Slave Cyl. And pull the Push Rod out from that side; roll it on a flat surface to confirm it isn't bent. Other than that, check your clutch pack to verify it is working properly. Could be some rust in there slowing things down. I would remove the pack and clean it up. Hope this helps
Spud is offline   Reply With Quote
Old Jan 28th, 2012, 8:52 am   #3 (permalink)
aswad's Avatar
Thanks Spud, i have checked the rod and its perfectly straight however i seem to have found out what is causing the problem.. please see the photos below
the last clutch plate is going out!! i tried harder springs and it didn't help.
Does this mean my clutch plates are gone? any ideas on how can i sort this out?
1098 Clutch lever stuck-photo-1.jpg   1098 Clutch lever stuck-photo-2.jpg   1098 Clutch lever stuck-photo-3.jpg
X-Rides :
Honda CBR1000RR 05
Kawasaki ZX10R 09
Old Jan 28th, 2012, 3:47 pm   #4 (permalink)
brian91cfr's Avatar
Images: 3
Check the stack height.
brian.
1998-916sps FOGGY REPLICA No91.
brian91cfr is offline   Reply With Quote
Old Jan 28th, 2012, 4:56 pm   #5 (permalink)
Looks like you've got boatloads of rust on your clutch plates. Take them out... clean them with contact cleaner and I'd take the time to polish the drive plates on a piece of 120 grit mounted to a piece of flat glass... I'd bet money after you do this the stack height will be back within specs... do a search in the forum to see what the acceptable range is for the stack...
'08 848, Red (Termi's.. not much else needed)
'01 ST4, Blue (Arrow Pipes, Ohlins Rear Shock, Alum. Swingarm, DD Headlight, CRG Levers, CycleCat Risers)
'02 Monster 750S i.e., Senna (Remus Pipes, Rizoma Triples & Clip-ons / Belt Covers/ Mirrors/ Sprocket Cover)
ducati_750 is offline   Reply With Quote
Old Feb 17th, 2012, 1:54 am   #6 (permalink)
aswad's Avatar
the stack height of my plates is around 39mm ... i tried cleaning the plates then tried a new barnet clutch plates and still the same problem the last friction plate pops out!
could it be the slave?
X-Rides :
Honda CBR1000RR 05
Kawasaki ZX10R 09
Question: 1098 Clutch Lever Stuck Spriggan Superbikes 7 Sep 30th, 2011 2:28 pm
749 / 999 / 848 / 1098 / S4R Clutch Lever motodisiac Parts and Accessories 0 Jan 19th, 2011 7:58 pm
1098/SF clutch lever free play BigLebowski65 Superbikes 1 Sep 19th, 2010 4:31 pm
Help Please - Stuck Clutch Lever - 696 TJLHeat44 Monster 4 Jun 2nd, 2010 8:07 pm
Shift lever getting stuck in 1st bobross Supersport 5 Mar 12th, 2008 8:13 am
