No front brakes 03 749 - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jan 20th, 2012, 10:05 am   #1 (permalink)
I purchased this bike recently in "as is" condition and the brakes haven't worked since I bought it a month ago. Long story short I bled the front brake system yesterday which yielded quite a few bubbles in the line, but I never got the pads to bite the rotors. I've noticed a small leak of brake fluid from the spot where the the fluid reservoir connects to the master cylinder. I would have assumed that it needs a new MC but I was able to bleed the brakes. Was I premature in finishing the brake bleed and there's still some air trapped in the lines? Is it perhaps the MC? Or is there something else entirely that I've missed?
99 750ss (RIP)
01 748s
08 848
00 748
00 996
04 999
09 D675
Fueratoma is offline   Reply With Quote
Old Jan 20th, 2012, 10:29 am   #2 (permalink)
There is a bleed nipple actually in the reservoir start bleeding from here first
Mr C is offline   Reply With Quote
Old Jan 20th, 2012, 9:03 pm   #3 (permalink)
smokey999's Avatar
Definitely start at the master cylinder first for bleeding air out of the master itself. Thats how you can figure out if the master cylinder is shot is if you can't get all the air out of it.
2003 999 "Terramoto"
2004 749 track bike "Princess"
2007 SV650 "Village bicycle"
smokey999 is offline   Reply With Quote
Old Jan 21st, 2012, 10:43 pm   #4 (permalink)
Ok, started to tackle this today before I realized I'm not quite sure how. The bleeder valve in the reservoir looks like a hex key will fit it, but there's a something metal and circular right in the middle of it that impedes a hex key from getting a good bite on it, and I don't want to round it over. Is there a special tool required to spin it?
99 750ss (RIP)
01 748s
08 848
00 748
00 996
04 999
09 D675
Old Jan 22nd, 2012, 4:51 am   #5 (permalink)
safetyfish's Avatar
Take the reservoir cover off
Using a syringe, suck all the fluid out
Refill with fresh fluid
The internal bleed nipple is loosened with a 6 (or a 5?)mm spanner
Pull the brake lever, loosen the nipple SLIGHTLY. (Too fast and fluid will spray all over the place)
Tighten the nipple
Release the lever
Repeat
If you are playing with a hex key then I think you are playing with the screw that holds the reservoir to the MC
SF
999R
998 Bayliss
safetyfish is offline   Reply With Quote
Old Jan 22nd, 2012, 5:19 am   #6 (permalink)
You usually undo the internal bleed nipple with a 6mm socket sounds like the head has snapped off. This has happened to mine too. if this is definatly the case you can bleed from the union on the master cylinder. Failing all that a bleed tool should do the job
Old Jan 22nd, 2012, 7:40 am   #7 (permalink)
SF
In my defense it was all of 9 degrees in my garage when I went out to work on the thing yesterday. I felt a bit rushed! That said, I think this is the case. I'll be a bit more patient and do a more thorough search in there today.
OR perhaps this is the case. Does anyone happen to have a photo of what that bleed nipple is supposed to look like? Does it stick up out of the black bolt? Or is it somewhere else entirely...?
99 750ss (RIP)
01 748s
08 848
00 748
00 996
04 999
09 D675
Old Jan 23rd, 2012, 8:32 am   #8 (permalink)
Giving this thread a quick bump. I'm assuming the bleeder nipple has snapped off because I really don't think there's a way to get anything on what I've seen in there. How do you bleed from the junction of the MC and the reservoir?
99 750ss (RIP)
01 748s
08 848
00 748
00 996
04 999
09 D675
Old Jan 23rd, 2012, 1:12 pm   #9 (permalink)
I just dug my M/C's out so I could show you. My brake side nipple snapped off.
1st pic shows what you should see and 2nd pic shows what you may well be looking at
There must be a way of getting the whole thing out and replacing with new parts from the dealer. To be quite honest I have not even tried yet.
You can bleed from the banjo at the M/C by just cracking it off and bleeding to make sure there is no air in there.
Old Jan 23rd, 2012, 3:28 pm   #10 (permalink)
Nail on the head, mr. C! Mine has been snapped off. I'll have to look into finding the new piece. In the meantime, can you explain in a little more detail how to bleed from the joint with the MC?
99 750ss (RIP)
01 748s
08 848
00 748
00 996
04 999
09 D675
Front brakes pulsing mainframe Superbikes 2 Jun 11th, 2010 12:00 am
1198S front brakes on 848? squids30 Superbikes 1 Sep 1st, 2009 11:49 pm
have a problem with my front brakes. can anyone help me DTA900ss Supersport 52 Oct 13th, 2008 6:21 pm
HM S Front Brakes - Noise tunefx HyperMotard 7 Jun 6th, 2008 11:58 pm
Front brakes on a 996 gt4play Superbikes 7 Jul 19th, 2006 6:02 am
