Jan 18th, 2012, 8:44 am
998R Found
I was recently lucky enough to have a 2002 998R fall into my lap and I am now the owner. How do you have one of the rarest bikes fall in you lap? I bought it at an IRS tax auction. You should all kick yourselves now for not going to that auction because it will probably never happen again  .
The good news about the bike is it appears to be in really good condition. It has under 15,000 miles on it but it has been rode. I'm not an expert, but all of the panels appear to be good with the exception of minor chips and scrapes, most of which look like they are from riding boots or suit. It started right up and was driven the 100 miles home with no problems. The headlights were dusty on the inside. I've taken them apart and cleaned them up. they look good now. Is this common for Ducatis or this model? I could not see an obvious source and if there is a prevention, I would do it. The two pouches of foam insulation on the inside of the carbon fiber side panel have deteriorated, so I will be purchasing new ones. Any good methods for removing the clips holding them on without risking the panels? I'm thinking a pair of tapered hooks to try and wedge into the spring arms.
The bad news is there is no plack, no manuals, no tool kit, and no history as of yet. This bike is number 470 of 700. VIN is ZDM3H99VX2B014699 which checks out as correct as far as I can tell. I am cleaning it up and will be finished tonight, so as soon as the weather clears I will get good pictures of the bike as detailed. If anybody knows any of the bikes history, it is a rare bike in a fairly small community, let me know. I will be doing research, but haven't had much luck other than the original purchaser and one other owner.
Because I don't have the manuals, I do have some stupid questions. Changing the air filters. The manual I have found on-line is for an 998S and it has split air boxes to remove the filters. These are one piece. The only way I can see to remove them is to pull the fairing and just pull them out the front. I didn't try it yet because I want to make sure this is right and I can actually put a new filter in this way. Anybody know anything?
Until the weather clears, here are some as purchased photos....
Jan 18th, 2012, 9:05 am
Dux... if you go to the Ducati US site you can download both the owners manual and master assembly/parts list for your bike in .pdf format. Follow this link and enter Year (2002), Family (Superbike), Model and Language. Ducati
That is in beautiful shape. I have an '02 748R and have the same headlight issue, only not as bad. Not sure why it occurs but it is a fairly common problem for the 916 series.
To get at the filters on the R you have to remove the tank... there is a single bolt at the rear of the tank which holds it down. Once the bolt is removed, pull the tank back away from the triple tree about an inch or so to disengage the guide pin. At this point, pivot the tank forward lifting the rear to gain access to the fuel pump lines, tank vent and electrical connection. These all must be disengaged, and the only tricky part will be the two fuel lines. It is easier to do this with someone helping, but if not, prop the end of the tank up on a small block of wood. There are tabs on the fuel line quick disconnects which must be pressed in towards the center of the connector... hold the tab pressed in and pull down on the line, gently. There is a plastic fitting inside the metal connector and it is somewhat fragile.
Once this is done, you should have access to the 2 air filters, one per side, built into the top half of the airbox, which is CF. Before attempting to pull them I would cover the shower injectors/intake stacks with a rag to prevent anything from getting in there.
Good luck.
ProphetPVD
'02 748R, #0954
Jan 18th, 2012, 11:05 am
wow!! what a beauty!!
whats with the plastic bag in the front wheel??
Jan 18th, 2012, 11:16 am
The Finder
Awesome find!
Fess up, how much of a steal was it?
2001 Ducati 996 R
1998 Ducati 916 SPS #909
2001 Ducati 996 track bike
1971 Honda CB450 cafe racer
1989 Honda NSR250 MC18/derestricted
2001 Derbi GPR 75
2000 Ducati 996 SPS #1134(sold)
2001 Ducati 996 Monoposto(sold)
1998 Ducati 748 (sold)
1999 Ducati Monster 900 (sold)
1995 Ducati 916 (sold)
1997 Suzuki TL1000s (sold)
1994 Honda VFR750 (sold)
1988 Yamaha FZR1000 (sold)
1990 Suzuki Katana 600 (sold)
1986 Yamaha Radian 600 (sold)
1985 Kawasaki GPz750 (sold)
1983 Suzuki GS450E (sold)
Jan 18th, 2012, 11:49 am
Very nice, congrats on the 998r it is a gem.
2009 Ducati 1198s "My first Ducati and I feel like I have starting ridding all over again"
Jan 18th, 2012, 2:10 pm
absolutely gorgeous! congrats! 470 of 700? is that what the plate on the triple tree says? i thought there were only 500 made? can someone verify? enjoy it!
Jan 18th, 2012, 2:18 pm
The Finder
500 996R's. (2001)
2001 Ducati 996 R
2001 Derbi GPR 75
Jan 18th, 2012, 2:20 pm
I'm not saying how good a deal it was yet, but it is really embarrassingly good I think. I have never noticed the plastic bag before you just pointed it out. Probably static cling from a Walmart bag from my cleaning supplies. Now I need to go home and see if it is still there  . It won't be in the next pictures. Thanks for the tip on the owners manuals, I'll go on there tonight. This computer can't pull up the Ducatiusa site for some reason. Good story on the auction though. First time they have paid off for me. I was lucky on the location since I needed to visit my daughter at LSU and went to the auction on the way there.
Jan 18th, 2012, 2:29 pm
The Finder
Well, whatever you got it for, as long as it was less than $15k you did well.
2001 Ducati 996 R
2001 Derbi GPR 75
Jan 18th, 2012, 2:33 pm
The 700 is correct but I fat fingered  on the 470. It is actually 460.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
998r
jserven247 |
Superbikes |
24 |
Oct 6th, 2006 2:16 pm |
'02 998r
serie1926 |
Superbikes |
0 |
Jul 1st, 2006 3:14 pm |
998R in NY
sps |
Superbikes |
4 |
Apr 14th, 2006 12:41 pm |
Still Looking For A 998r
sps |
Superbikes |
3 |
Mar 24th, 2006 3:29 pm |
