D16RR Display immobilizer question - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jan 16th, 2012, 7:43 pm   #1 (permalink)
I bought a D16 from a salvage auction, and as it turns out the auction itself has lost the display. I've heard rumor that the D16 immobilizer process is just in the ECU and key, and does not go with the display. Anyone ever ran one without gauges, or with aftermarket display WITHOUT flashing the ECU?
My choices are:
1. Buy a new oem display, and flash the ECU (hopefully) to accept it ($2000)
2. Buy a Microtech ECU and run an aftermarket or oem display ($?)
3. Buy a matching set ECU, Key, and Display ($3500)
asphalt is offline   Reply With Quote
Old Jan 16th, 2012, 8:04 pm   #2 (permalink)
Extended Member
CAlexio's Avatar
Good luck with that process, I ran into a dead end with that situation on my hyper... Was able to transplant internals of my dash to a new case.,.. Otherwise I was screwed.
Not to Off topic, but tell us details about the auction and the bike... Good price? Condition? Repairs needed?
Old Jan 16th, 2012, 9:22 pm   #3 (permalink)
disable immobilizer in OEM ECU or run Microtec ECU. Should be able to find a 848/1098/1198 dash unit for much less than a desmo unit
-MATT
'05 749R #233
Old Jan 16th, 2012, 9:35 pm   #4 (permalink)
since you brought that up...i recently found a salvage Desmosedici for $15,000. Most damage was in the rear tail, seat, and exhaust along with the typical scratched fairings and levers.
2010 Ducati 1198
2007 Kawasaki ZZR600 (sold)
avaipan2 is offline   Reply With Quote
Old Jan 16th, 2012, 9:55 pm   #5 (permalink)
Two words: ...you lucky son of a gun! That is awesome....post some pics.
Ignatius_Riley is offline   Reply With Quote
Old Jan 16th, 2012, 9:57 pm   #6 (permalink)
Ducatierv's Avatar
That one sold today for over $20k
1199 Panigale Tricolore
996RS Corse - Ben Bostrom's #155 Vance & Hines Racebike
05 1122R Ducshop stroked 999R "Big Meanie" Racebike
08 D16RR
03 999R #171
06 999R Motocorse Racebike
95 916 x 4 [Varese Bikes]
00 996SPS "Roxanne" #1418Racebike
00 996SPS Rebuild in progress
99 996SPS
98 916SPS #904
98 916SPS #640
98 748SPS RS spec NCR racebike
00 748RS
93 888SPO
99 748 with 853 kit 700miles from new
05 749S CCS Racebike
00 984R next project!
Bimota YB11 Attack Race Motor
MV Agusta F4 ORO #293
05 MV Agusta F4 1080 CCS Racebike
96 944SS extensive mods(nearly finished)
92 944 CCS Racebike rebuild in progress
88 Paso 750 Limited
90 851 SuperBike
99 996 Biposto FOR SALE
01 996 Biposto
06 749D
99 Laverda 750 Formula
Ducatierv is offline   Reply With Quote
Old Jan 17th, 2012, 1:45 am   #7 (permalink)
I think the 1098 Dash should work on a D16RR - they appear to be physically identical, however note they are not actually identical - the D16RR dash reads to 4,000rpm in the first major increment, the 1098 dash reads to 1,000rpm in the first increment. Thus the top reading on a 1098 is 13,000rpm whereas on the D16RR the maximum reading is 16,000rpm.
If you want to fix the bike properly just grit your teeth and try to source a D16RR instrument panel.
Andrew...
Andrew is offline   Reply With Quote
Old Jan 17th, 2012, 3:38 pm   #8 (permalink)
I've done the research now, and man its an ordeal.
The D16rr has an immobilizer, but not the same as other Ducs. The firmware programmed in the dash houses the immobilizer software. It searches out on powerup for the RF identifier of its married key. As I am missing this display, we have a problem. According to Ferracci, (thanks Eraldo) I can buy a new oem virgin dash for $1250 and it will marry as soon as powered up, possibly with a factory program, or maybe on its own, with the key I have in the ignition at that time.
My other option is to buy a different oem dash, used, and install a Mircrotec ECU from Ducshop, where they have designed one to talk to the dash, and ignore the immobilizer. This will also get me better control of the bike, with software that can tweak maps held in the ECU, and tweak traction control slip maps too.
If only the auction hadn't lost the damn display, this wouldn't be an issue.
Old Jan 17th, 2012, 3:42 pm   #9 (permalink)
Andrew...
I was told the connector is different, and also the software is completely different. It would not display correctly, not in RPM or traction settings.
Old Jan 17th, 2012, 3:42 pm   #10 (permalink)
Will post pics when it gets here around the 27th.
Looking at a 749....Immobilizer/Key Question Biezestreet Superbikes 16 Aug 3rd, 2010 2:06 am
Immobilizer question Jellonailer Superbikes 4 Jul 17th, 2010 5:47 pm
Immobilizer Question rphillips52 Multistrada 3 Sep 19th, 2009 4:16 pm
Immobilizer question? AJLDuc Sport Classic 1 May 7th, 2008 8:04 am
749 new key immobilizer question bikesandcars Superbikes 2 Nov 22nd, 2007 12:36 am
