Thread lock on LHS crank case cover bolts? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old Nov 1st, 2006, 8:55 am   #1 (permalink)
dragknt's Avatar
Question Thread lock on LHS crank case cover bolts?
Last question for a while, promise. At least a few days...
Should I use thread lock (blue) on the crankase bolts? On the starter mounting bolts? On the LHS crankshaft bearing cover plate bolts? Should I just use blue thread locker on all the bolts? heheh
Should I pull the flywheel nut off while I'm in there and re-thread-lock it, or only if it's loose?
And is blue threadlock ok, or should I use red for anything?
Also, what locking compound/sealant should I use if I have to replace the fuel line fittings in the gas tank (the female ends, not the male ones). I ordered a set off ebay that supposedly fit the 916, but it comes with both male and female fittings, and I don't know if the male ends in the kit will fit the OEM female fittings in the tank.
Thanks!
1998 Ducati 916
dragknt is offline   Reply With Quote
Old Nov 1st, 2006, 9:35 am   #2 (permalink)
ducati_atx's Avatar
I put blue threadlock on all the bolts. (also, you can see when you pull them out - they should still all have some residue on them) Be careful using red anywhere you ever plan to take off again.
As far as the nut - I would inspect it, and if you have the correct socket - I would go ahead
and re-locktite it since you have the cover off already. If you dont have the tools, Id probably
just leave it alone.
Not sure about the other.
ducati_atx is offline   Reply With Quote
crank case breather question kt57 Supersport 11 Jun 4th, 2009 9:37 pm
Over-tightened oil drain plug...crank thread stripped..now what? hypnotic Superbikes 17 Sep 3rd, 2007 9:05 pm
who makes a seat cable release lock cover? Bevel-Heaven Superbikes 5 Oct 6th, 2006 5:56 am
Water pump cover / Drain plug thread rikten Superbikes 9 May 30th, 2006 2:22 pm
