Jan 14th, 2012, 8:45 pm
Cam pulley nuts
Does anyone know if nylon lock nuts will work in place of the "special" castle nuts? Feel free to voice your opinions.
Thanks!
2000 996 SPS #1203
Jan 14th, 2012, 8:53 pm
I don't think you'll find any nylock nuts in the diameter and pitch.
Threads used are 15x1.0 and 17x1.0, very oddball.
The pulley nuts are essentially bearing locknuts, you can find them through industrial bearing supply places. 15mm is called a km2 and 17mm is called a km3 I think, and use special lock washers.
Jan 15th, 2012, 6:40 am
Vee-Two of Australia supplied conventional nuts with their adjustable cam pulley kits.
916 & M944 'project'.
Jan 15th, 2012, 6:46 am
Thats a good question.
I have been thinking of squishing the used ones a little bit and putting the locktight to them.
$10 bucks a piece the little buggers.
Jan 15th, 2012, 9:56 am
Nylon or "nyloc" nuts are not designed for the temperatures encountered on a running engine. There may be some specialty material ones out there but I've never seen them. Now they may work just fine but I wouldn't recommend taking the chance. Anyway get a set of nuts for your tensioners for $7 a set from desmotimes.com .
"My father would want me to be firm in the right, as he always was. The author of all things watches over me......and I have a good horse." Mattie Ross (True Grit)
“Merciful Father, I have squandered my days with plans of many things. This was not among them. But at this moment, I beg only to live the next few minutes well. For all we ought to have thought, and have not thought; all we ought to have said, and have not said; all we ought to have done, and have not done; I pray thee God for forgiveness.” Ahmed Ibn Fahdlan
"Now think real hard. You been bird-dogging this township a while now. They wouldn't mind a corpse of you. Now you can luxuriate in a nice jail cell, but if your hand touches metal, I swear by my pretty floral bonnet: I will end you." Capt. Malcolm Reynolds
'11 Harley-Davidson Super Glide Custom.
’03 749 Biposto “Rosa”.
'93 Katana 600 "Rat Kat"(SOLD)
'09 Honda Rebel 250
Jan 15th, 2012, 10:45 am
Got a little confused rereading the post, the small ones on the pulley wheels ate not to bad. Desmotimes 7.00 U.S. a set. Just purchased 4 sets for my stock. Now the larger lock nuts on the cams them selves are up there. About 21.00 U.S. each. Just received the tools to take them off when I do the cams if necessary. I have used those type of nuts before. It was the bolt that could not be used again since lock nut tends to bight in. Not sure with these. Not to hijack the thread but are these indeed reusable or is it or the cam and nut a one time separation? I could of swore it was just the three small allen heads that had to be loosened to change the cam timing, but not certain.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
Jan 15th, 2012, 11:50 am
Thanks for all the replies...To clarify, I'm talking about the nuts that hold the toothed belt pulleys to the camshafts.
2000 996 SPS #1203
Jan 15th, 2012, 5:20 pm
In an aircraft application they are referred as as an all metal stop nut. You do not want a nylock in a heat sensitive environment. With some research you may be able to find a metric counter part. If you do let me know because 21 bucks + each does not thrill me. Good luck
Jan 15th, 2012, 7:08 pm
Old Cafe Racer
davy-j
2000 748 57,095 km
2007 Cagiva Mito 125cc 2 stroke
1967/73 Triumph Daytona T100R Cafe Racer project bike (almost finished)
Sun's out, lets ride
Jan 26th, 2012, 3:24 am
Saw these on ebay, you can use a proper socket on them;
eBay - The UK's Online Marketplace
Any comments?
